augidog
924guy
Posted: Fri Mar 11, 2005 12:27 pm Post subject: |
it should, i dont see any reason why it wouldnt..so far as i know there wasnt any change in the mounting flanges that would affect overall fitment.. i might be wrong, but i think something like that would of stuck with me.. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Raceboy
Posted: Fri Mar 11, 2005 5:20 pm Post subject: |
Do you mean just TB or with intake? I have swapped newer intake to early 924, no problems. And about just TB, I think it will fit OK. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
My924gtc
Posted: Fri Mar 11, 2005 10:31 pm Post subject: |
You are all set either way. I know you are going to put the entire intake on so that you get the script on the top, but the TB will swap on too if you go that route. You won't have any need for the TPS's but everything else is pretty much the same. _________________ MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands" |
augidog
Posted: Fri Mar 11, 2005 11:17 pm Post subject: |
| My924gtc wrote: | | I know you are going to put the entire intake on so that you get the script on the top, |
yes, that is an added plus and I like to remind myself as much as possible that I have a Porsche.
(I wish it lit up and flashed when I opened the hood.)
It looks to be coming with a better decel valve, cold start attached etc.
Ebay is your friend.
| My924gtc wrote: | | You won't have any need for the TPS's but everything else is pretty much the same. |
What are you referring to, the little strange box on the TB? ? I'm not familiar with that. What are the TPS’s _________________ 1978 924 95 mile daily driver.
Posted: Fri Mar 11, 2005 11:19 pm Post subject: |
| Throttle Position Switch, used in later cars.... |
924guy
Posted: Fri Mar 11, 2005 11:30 pm Post subject: |
| augidog wrote: | | My924gtc wrote: | | I know you are going to put the entire intake on so that you get the script on the top, |
(I wish it lit up and flashed when I opened the hood.).........
No problem!! a couple of 15kmcd leds tied into a flasher circuit, mounted to the under side of the hood..ofcourse itll only show at night, buts not to hard to make it a little light show .  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
