Posted: Thu Jul 07, 2005 6:48 am Post subject: Exhaust manifold removal |
I removed and refitted the manifold with the head on.
What a PITA.
Not recommended unless you have the time and patience.
I had to remove all the heat shields so I could get my hands in there as well as the steering join to the steering box. (RHD)
I replaced all the studs with SS bolts and studs.
No leaks and runs well.
FWIW...... use 8x 40mm bolts or 50 mm studs after re-tapping the holes to the bottom in the head. I had to use studs for the bottom of 2 & 3 because I could not get bolts in there.
Well the car goes for its road worthy certificate today. _________________ Porsche 924 1984 (UK import) NA
endwrench
Posted: Thu Jul 07, 2005 9:03 am Post subject: |
Ouch! Right hand drive!! Must have left a little knuckle skin behind on that one!!!
Todd |
Posted: Thu Jul 07, 2005 10:57 am Post subject: |
And donated a pint to the local mosquito population _________________ Porsche 924 1984 (UK import) NA
Posted: Thu Jul 07, 2005 12:23 pm Post subject: |
| I didn't know Mozzies drank bundy... |
Posted: Thu Jul 07, 2005 2:58 pm Post subject: |
They are North Qld tropical mossies. _________________ Porsche 924 1984 (UK import) NA
Gram
Joined: 08 Feb 2005 Posts: 357 Location: Northland, New Zealand
Posted: Thu Jul 07, 2005 3:53 pm Post subject: |
Nice one Ozzie..looking at mine I can see the problems you had..not a lot of room to work there. _________________ '82 924 NA Euro (hers)
'98 Audi A4 TDI (ours) |
Posted: Thu Jul 07, 2005 4:24 pm Post subject: |
She is now registered....... OZI 924 _________________ Porsche 924 1984 (UK import) NA
Posted: Sat Jul 09, 2005 1:03 pm Post subject: |
A few problems were picked up during the safety test.
Engine mounts have to be replaced.
Crank oil seal leaking.... I've replaced it already but still leaks.
Those mounts are $360 for the left and RH is not available in Aust.
Got them from Paragon for $370.. incl freight.
Pays to look around. _________________ Porsche 924 1984 (UK import) NA
