isuras2
Posted: Thu Jun 30, 2005 10:43 pm Post subject: Motor/Tranny Oils? |
What motor oil do you all use? I was thinking that 10W30 is fine (Haynes), but read somewhere that 20W50 is what should be used. 80W90 for transmission?
Thanks, _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
John Brown
Posted: Thu Jun 30, 2005 11:02 pm Post subject: |
Most of us, me included, probably err on the side of an oil that is too 'heavy'. Partly a trickle down from those of us running on tracks and 'if it's good for them it's good for me'. Wrong.
Especially with the improvements in oils since 1982, I would suggest that if your pressure is reasonable 10W30 is fine. The 15W50 synthetics also are OK if you want to anti up the cost. If we were running a 924 on the street I would be using 10W30 or 10W40 plain or blended.
I use straight 50, but that is on a track, we ALWAYS have time to warm the car, and I put 10W30 in for the off (cold) season. _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
gone but not forgotten: original 924.org car - 82 |
isuras2
Posted: Fri Jul 01, 2005 12:03 am Post subject: |
So if I want to buy one oil to use year-round, 10W30 would be the one? _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Diesel
Posted: Fri Jul 01, 2005 1:54 am Post subject: |
What does it say in the owner's manual? That's what I always rely on. _________________ Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D |
isuras2
Posted: Fri Jul 01, 2005 2:28 am Post subject: |
I don't have an owners manual, but Haynes says:
Summer SAE 30W
Winter SAE 20W
Tranny SAE80
I assume that SAE 30W = 10W30 and SAE80 = 80W90? _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
Raceboy
Posted: Fri Jul 01, 2005 2:59 am Post subject: |
Hey guys, it depends of the shape of the engine too. And one more little thing: time has passed and so has technology. You don't have to use fully synthetic oil but 10W-40 semisynth is the best choice for the non-rebuilt 924 NA engine, already tried many of them. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Fri Jul 01, 2005 4:27 am Post subject: |
| Porsche's latest recommendation is that all Porsches ever made should use 0W-40 Mobil 1. |
John Brown
Posted: Fri Jul 01, 2005 12:35 pm Post subject: |
| Diesel wrote: | | What does it say in the owner's manual? That's what I always rely on. |
Dan's correct, as always. Found the OM for the 80 and factory spec is 10W40 or 15W50 or 20W50. With the 15W50 having no upper or lower temp limits. I stand corrected!
Still, tempering the OM info with Paul's information about the factories updated guidance which takes into account the changing lubricant technology; I think I might gravitate back to the 10W40 again!!!
Ah!! Too many choices. Just put something slippery in.  _________________ John
80 931 - #931 44Cup
maireeka
Joined: 29 Aug 2004 Posts: 299 Location: North Alabama
Posted: Fri Jul 01, 2005 1:40 pm Post subject: |
I use 20w50, but my car's fairly leaky and I've had a couple of problems with low pressure when the engine's a bit on the hot side. _________________ 1977 Porsche 924 red and READY! |
numbbers
Posted: Sat Jul 02, 2005 10:39 am Post subject: |
Well, all of the regulars no where I stand. Mobil-1, Mobil-1, Mobil-1. I run 15W-50 in the turbo, and the same in my other cars in the summer. In the winter, I run 5W-30. I would try the 0W-40, but I have never found it in a store. _________________ 1980 924 Turbo |
Posted: Tue Jul 05, 2005 5:22 am Post subject: |
My 2001 986 has 46,000 miles and it's oil has been changed 4 times. the oil level has never left the full mark between changes and the oil is almost clean after a year of use.
Porsche recommends that it's oil be changed every 15,000 miles or once a year unless the car is driven at least 9,500 miles a year, then it can wait until 15,000 miles. They also recommend that the oil filter be changed every other oil change! |
isuras2
Posted: Wed Jul 06, 2005 7:49 am Post subject: |
I got some regular Quakerstate 10W-30 that I will use. I will see how that works and will go from there. _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
CBass
Posted: Mon Jul 11, 2005 7:08 am Post subject: |
I run Castrol GTX 10W40 in my 924 and my GTI, as well as in my parents Passat 2.0 16v.
The best oil depends on climate, where I live it never really gets below 25f/-5C, and rarely above 100f/30C. Hence I don't need to run 10W30 or 20W50, etc. If you live in a climate where it gets really cold, or really hot, you'll want a lighter weight or heavier weight oil, accordingly. Synthetics work better than conventional oils in extreme temperature conditions.
If I were to own a 931, I would run synthetic because the turbocharger is oil cooled, and that puts a lot of stress on the oil. _________________ '81 931 in various states of assembly |
