Posted: Mon Oct 08, 2007 7:52 am Post subject: Overnight no-start |
Drove the gleaming white car to work three times last week, and tried to start it saturday, and it wouldn't cooperate. I think it was firing intermittently due to some bluish smoke coming out of the back, yes, I did pump the pedal a few times! So, I left it alone for awhile, thinking it would fix itself. Alas, today it did the same thing, I did get it running and drove it around the block, and it seemed quite right. But, after shutting it off and trying to restart it, it wouldn't start. I put a timing light on the coil wire, and not much going on there, no steady blinking of the light. Weird thing though, when I shut the key off, it would fire a couple of times and quit. Does that sound like a short somewhere, or did the coil just decide to die on me? Maybe a sticky relay? Dave _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Cone_Eater
Joined: 29 Jul 2007 Posts: 126 Location: Marshfield, MO
Posted: Mon Oct 08, 2007 1:39 pm Post subject: |
| you can get this tool called an "inline spark tester" and put it between your dist. and coil. If it lights up then your coil is working. Does the car not start when it is cold? |
Posted: Mon Oct 08, 2007 10:55 pm Post subject: |
well, the car fixed itself. Not sure how it got into my tools, but I went out a few hours later, and it started. And it started five times in a row, so not sure what happened. Of course, I don't trust it now. _________________ '83 944 Track car.
