924er
Joined: 10 Jan 2006 Posts: 339 Location: Los Angeles California
Posted: Tue Jan 31, 2006 10:26 am Post subject: worn cramshaft |
| Quote: | | 1. Worn camshaft. Listen for 'ticking' noise from top of engine. |
i found that on the FAQ on this website. i guesss then i got a worn camshaft i got ticking noise. can i easily replace the camshaft?? _________________ 80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy |
Posted: Tue Jan 31, 2006 11:03 am Post subject: |
You need to pull the valve cover and have a look first. Worn cam lobes will be easily apparent - they'd be rounded at the edges. The problem might only be that the valves need adjustment. While in there, also verify that the cam oiler elbow (small plastic piece at the front) is intact. _________________ "..it's made in Germany. You know the Germans always make good stuff."
924er
Posted: Tue Jan 31, 2006 2:24 pm Post subject: |
thanks alot ill see what i can do _________________ 80' Porsche 924 NA - Slower then a S L O W
Posted: Tue Jan 31, 2006 2:40 pm Post subject: |
This is the same problem you stated in this thread?
I totally agree with Smoothie. And with the previous suggestions.
Check the lifter adjustment first. Also check the oiler elbow.
These engines all "tick" when starting from cold and may "tick" more than some other engines, due to the design. If you've never heard this type of engine before, it may sound abnormal. But it's not.
That's not to say you don't have a worn camshaft or other problems. I'm just suggesting, like others, that it's probably something more simple. _________________ '80 924 Turbo |
924er
Posted: Tue Jan 31, 2006 5:39 pm Post subject: |
ok ill look at it thanks alot _________________ 80' Porsche 924 NA - Slower then a S L O W
