924 idle engine speed 1500 rpm
Meneer aard
PostPosted: Mon Jan 30, 2006 7:35 pm    Post subject: 924 idle engine speed 1500 rpm Reply with quote
When i drive my car, and stops or shifting the engine makes arround 1500 rpm.
When i start (cold start) de engine speed is 900-1100 rpm. I think the throttle cable is not function well?
Or maybe is the problem somewhere else?
PostPosted: Mon Jan 30, 2006 7:38 pm    Post subject: Reply with quote
Most engines when hot should idle approx 900 rpm.
This will be different when cold, how different depends on the state of the WUR and AAV.
I would say someone has adjusted your cold idle to cover problems with these two items.
Meneer aard
PostPosted: Mon Jan 30, 2006 10:05 pm    Post subject: Reply with quote
Indeed, 15 minutes ago i drive to home, and with hot engine the idle speed is 1100 rpm, when you give a little bit more power than the engine rpm is 1200 rpm, and the next traffic lights is the speed arround 1100 rpm :?
The kjet valve, for the extra air circuit when the engine is cold, was broken, other wise the valve does not open. I replaced that valve and fisrt impression was perfect idle @ 1100 rpm with cold start.
PostPosted: Mon Jan 30, 2006 10:22 pm    Post subject: Reply with quote
When cold:
The air valve opens when cold to allow more air to lift the air sensor and increase the idle speed temporarily.
The WUR reduces the pressure holding the air sensor down allowing it to lift further and rich the mixture.
When hot the air valve and WUR should not affect the idle. This is why all adjustments for the idle and air/fuel mix should be done when hot.
People compensate by adjusting the cold idle when the problem is the WUR or AAV.
PostPosted: Tue Jan 31, 2006 4:13 am    Post subject: Reply with quote
924NA? 19??
Put the model and year in your signature.
Meneer aard
PostPosted: Tue Jan 31, 2006 5:32 am    Post subject: Reply with quote
Smoothie wrote:
924NA? 19??
924 Euro 1977.
924er
PostPosted: Tue Jan 31, 2006 9:57 am    Post subject: Reply with quote
true that ozzie ur right about that. when my car is cold in the morning it starts up quick but idles very low until the car gets warm then idles at 900rpm.
Q: hey how come when i turn the ignition off on my car it shuts off, then shakes and sounds pretty ugly then white smoke comes out my intake, i checked the FAQ no answers. usually i found a way to do it, is to turn the key slowly when shutting it off, then it wont shake.
thanks alot, this problem is really bothering me
80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
D Hook
PostPosted: Tue Jan 31, 2006 11:16 am    Post subject: Reply with quote
Sounds like dieseling. Sometimes, IIRC, it makes the engine run backwards, pushing fumes out into the intake. Bad for the engine internals. Usually caused by hot spots of carbon in the combustion chamber and a leaky fuel injector. Someone correct me if I'm wrong. (I'm only going off what I recall about a crappy chevy engine I once had that would do the same thing.)
'80 924 n/a SOLD
924er
PostPosted: Tue Jan 31, 2006 12:18 pm    Post subject: Reply with quote
yep, i think ur right. i did some google search:
http://en.wikipedia.org/wiki/Dieseling
anybody else have any idea????
PostPosted: Tue Jan 31, 2006 1:54 pm    Post subject: Reply with quote
I think I mentioned in your other post that it was probably running a bit rich.
Adjust the fuel air mix to correct value and put in fuel injector cleaner and run on premium 98 ron unleaded.
This will hopefully then clean out the carbon buildup.
PostPosted: Wed Feb 01, 2006 6:41 pm    Post subject: Reply with quote
No, you're spot-on there.
