leadfoot
Posted: Thu Nov 03, 2005 10:35 am Post subject: suspension bushings in AUS |
I've call noltec (AUS) for some urethane bushings, they have done a set for the 924 in the past but are unsure if they still have the tooling, they're getting back to me on this.
Ozzie you were interested at one stage in getting bug pack bushings, are you still interested??
Are there any other guys in AUS interested in obtaining bushings??. When noltec get back to me I'll have a difinitive list of what the can supply and cost... i.e a-arms,strut bump stops, sway bars etc...
Othewise I will be going for bugpack from international suppliers...
Leadfoot _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
Posted: Thu Nov 03, 2005 10:53 am Post subject: |
I'd be very interested in seeing what they can do and their pricing. _________________ 1979 924 (Gone to a better place)
Posted: Thu Nov 03, 2005 11:52 am Post subject: |
I am looking at getting some for the alternator from Fulcrum suspension.
I have to pull it off to get measurements again.
Inner dia, outer dia and length. _________________ Porsche 924 1984 (UK import) NA
tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Thu Nov 03, 2005 4:58 pm Post subject: |
| Ozzie wrote: | | I am looking at getting some for the alternator from Fulcrum suspension |
I need some too 'cause I found out the hard way that the Aus bushing ain't the same as the US ones. Would appreciate you letting me know how you go Ozzie. _________________ TJ
Silver '82 924 NA 5-Speed Manual |
Posted: Thu Nov 03, 2005 5:13 pm Post subject: |
I gotta get the vernier out - pull the alternator and meaure up.
Not this week.
My son has dropped his car in my lap. Brakes all round, ring gear on flywheel and other dramas. _________________ Porsche 924 1984 (UK import) NA
leadfoot
Posted: Mon Nov 14, 2005 2:35 pm Post subject: |
Waiting for a guy to get back to me from noltec... their 924 bushings are under development and I'm getting an ETA on finish....
they are going to be offering;
inner front and rear bushings for front control arm in standard form...
as well as a rear bushing for the front that has camber adjustment...
there is also a castor kit being made...
I also contacted VSI imports in S.A for a cost estimate for bugpack bushings as they are the distributors for these, they only supply front/rear bushing for the front control arm but are out of stock in the rear bushings at the moment, I will know tommorow if they can still get them imported though and get a cost estimate on these.
That's it for now...
Posted: Tue Nov 15, 2005 11:47 am Post subject: |
do you notice that Noltec also sell a DIY coil-over kit for struts? Grab a copy of the current Zoom magazine to see the process. _________________ 1979 924 (Gone to a better place)
leadfoot
Posted: Tue Nov 15, 2005 6:43 pm Post subject: |
Yeah got any idea on the cost, as to get my struts modified with threaded perches/preload springs/koni yellows / new coils etc is about $1500 from top performance...
so if a direct swap out is available cheaper then that would seem more feasable...
I'm thinking that just a new lowered spring and a change of shock is more affordable at the moment... around 250/300 springs + $660 for the shocks
tj924
Posted: Tue Feb 07, 2006 1:58 pm Post subject: |
| tj924 wrote: | | Ozzie wrote: | | I am looking at getting some for the alternator from Fulcrum suspension |
I need some too 'cause I found out the hard way that the Aus bushing ain't the same as the US ones. Would appreciate you letting me know how you go Ozzie. |
Hey Ozzie, did you end up getting to the alternator bushings? _________________ TJ
