plyhammer
Joined: 14 Dec 2004 Posts: 82 Location: greenville, ohio 45331
Posted: Sat Feb 11, 2006 2:36 am Post subject: catalytic converter |
| What year did the 924 start to have a cat, or do they all have a catalytic converter? I have to redo the exhaust and need to figure out if I need one and am to lazy to crawl under. thanks ps. mine is a 79 na |
Posted: Sat Feb 11, 2006 4:35 am Post subject: |
| All US market 924 models came with a cat. |
alxch1n15
Joined: 26 Nov 2004 Posts: 261 Location: Madison, Wisconsin
Posted: Sat Feb 11, 2006 5:00 am Post subject: |
what is the year cut off for having to have a cat? i know in madison we have no emissions requirements, but have heard that if your car is older than a certain year, you dont need to have one? _________________ '81 924 n/a |
Posted: Sat Feb 11, 2006 5:10 am Post subject: |
Emissions equpiment requirements vary from state to state and county to county.
You need to check with your local vehicle licensing department to see what the requirements for your area are or are not.
Remember that if you alter your vehicle (like remove the smog equipment) then move to a different area, the laws may be different, you you may be subject to criminal penalty for altering the vehicle. At the very least, before you regiustered teh car in the new location, you would probably be required to restore the missing equipment regardless of the replacement cost.
Here in CA cars manufactured before 1975 are emissions exempt, and cars manufactuered after that will stay emissions equipment required and tested bi-annually, no matter how old they become. |
plyhammer
Posted: Sat Feb 11, 2006 5:20 am Post subject: reason |
| Thanks, the reason I ask is that my mechanic said that the cat may be "clogged" and so I thought about just removing it. Any drawbacks? |
Posted: Sat Feb 11, 2006 6:18 am Post subject: |
Drawbacks?
You mean besides the fact that you would be poisoning all of us, it may be illegal where you live, and your car probably won't run as good as it would with a properly functioning cat? |
Min
Posted: Sat Feb 11, 2006 7:40 am Post subject: |
| gohim wrote: | Drawbacks?
I must say, I love you sometimes gohim.
Min |
