stexch
Joined: 05 Dec 2003 Posts: 90 Location: Mankato, KS, USA
Posted: Wed Feb 08, 2006 3:31 am Post subject: what oem wheels interchange? |
| My car came without a spare, so I'm going junkyarding to try and find one that will work (4-bolt). Please let me know what other cars used this bolt pattern&offset, as Porsches are scarce in this neck of the woods. Thanks! |
crazyinkc
Posted: Wed Feb 08, 2006 5:21 am Post subject: |
I have several you can have if you want to swing down to Kansas City . |
StienbargerR
Posted: Wed Feb 08, 2006 8:12 am Post subject: hondas |
alot of lower grade cars have four bolts... like, the base model civic has four bolts. Im sure you can find one at a junk yard
Ryan |
MunkPuppy
Joined: 02 Jul 2003 Posts: 419 Location: New Westminster, B.C., Canada
Posted: Wed Feb 08, 2006 8:19 am Post subject: |
WHOA!!!! Stop right there...
just because there's 4 holes, doesn't mean that it will fit... you have to think about the distance from the center of the wheel to the hole, and not all are the same.
Fortunately, from what I've been told, some Ford 4-bolt wheels will fit, but I'm not sure which years and which models. Your best bet is to find the bolt pattern spec (I'm too lazy to find it right now) for yor car and match it up with another vehicle (like I said, check the 80s & 90s Fords, I'm pretty sure some will match). _________________ '80 931 FOR SALE
-Anton Szandor LaVey |
tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Wed Feb 08, 2006 8:32 am Post subject: |
I'm positive there are heaps of guys on the board with spare 4-bolt rims they'd be happy to part with. Post in the "Cars and Parts Wanted/For Sale" forum. _________________ TJ
Silver '82 924 NA 5-Speed Manual |
Chrenan
it's 4x108 which is not common, also has a strange offset, so you are best just to get another 924 wheel, they are usually free to a good home _________________ 1987 951 - M193 Version for Japan |
tj924
Posted: Wed Feb 08, 2006 8:36 am Post subject: |
| Chrenan wrote: | | ...just to get another 924 wheel, they are usually free to a good home |
If only that were true in this neck of the woods. The Porsche parts places in Aus want about $150 + shipping for a plain old 924 rim! _________________ TJ
Andrew NZ
Posted: Wed Feb 08, 2006 9:06 am Post subject: |
I have Peugeot wheels on mine. _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
Posted: Wed Feb 08, 2006 9:15 am Post subject: |
http://www.924.org/techsection/9brakes.htm#1 - Wheels and tires _________________ "..it's made in Germany. You know the Germans always make good stuff."
stexch
Posted: Thu Feb 09, 2006 7:01 am Post subject: |
| About the only things rarer in this area than Porsches are Peugots. Crazy in KC is going to get me one. Thanks for all the input! Phil |
CSP
Posted: Fri Feb 10, 2006 11:49 pm Post subject: |
| Good topic. What is the offset for the 4x108 stock 924? |
santi
Joined: 24 Jan 2006 Posts: 30 Location: SPAIN (europe)
Posted: Sat Feb 11, 2006 10:31 am Post subject: |
Its easy to find!!Peugeot, Ford and Citroen, if use 4 bolt..have 4x108mm..Then principal brand of ring have this size..
The other problem is the ofset but is easy to put a spacer..The 8spoke have 20mm of ofset or ET. _________________ Im from Madrid (Europe), my english is not very fine...SORRY!!! |
Pca944
Posted: Sun Feb 12, 2006 6:45 am Post subject: |
As the tech section says, there are a few other wheels that will interchange, but for the most part 4x108 is hard to come by. But I believe the 924's came with a full size rim as a spare (basket weave design) so if you can find a 924 you shouldn't have trouble with a spare.
I'm selling a set of 4x108 spiderwebs if you interested though. _________________ 1986 944 | 1978 924 (FS) | 1982 931 | 1980 931 |
924er
Joined: 10 Jan 2006 Posts: 339 Location: Los Angeles California
Posted: Sun Feb 12, 2006 9:48 am Post subject: |
hey i took out my spare so i can fit my big bong inside  _________________ 80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy |
