Flywheel removal.
garyj19
PostPosted: Tue Apr 18, 2006 9:04 am    Post subject: Flywheel removal. Reply with quote
how do i go at taking the flywheel off? i need to get to the rear main seal to replace it, and when i put the wrench on the flywheel bolts, it just spins. how do i stop this?
early 77 924 na
PostPosted: Tue Apr 18, 2006 9:34 am    Post subject: Reply with quote
Flywheel lock?
Screwdriver jammed in the ring gear and levered against the starter hole?
Impact wrench?
garyj19
PostPosted: Tue Apr 18, 2006 2:11 pm    Post subject: Reply with quote
Our impact wrench doesnt fit into the space that we have. we just moved the clutch bellhousing back about 4 inches. i will try the screwdriver idea. thanks.
early 77 924 na
PostPosted: Tue Apr 18, 2006 2:18 pm    Post subject: Reply with quote
remove the bellhousing entirely, you will have to to be able to remove the flywheel anyways
3 928s,
PostPosted: Tue Apr 18, 2006 10:49 pm    Post subject: Reply with quote
Try the poor mans' impact wrench - smack your wrench with a mallet. I used this technique in the Navy to remove flywheel bolts with my engine on a workbench and nothing to imobilize the flywheel.
PostPosted: Wed Apr 19, 2006 4:38 pm    Post subject: Reply with quote
Figured you for a tiffie. (naval artificer)
