8 Cylinder Fuel Distributor for the 931 GT
dpw928
PostPosted: Sat Mar 04, 2006 1:00 pm    Post subject: 8 Cylinder Fuel Distributor for the 931 GT Reply with quote
Thought some of you might be interested in the following thread since using the Mercedes distributor was discussed previously.
http://forums.rennlist.com/rennforums/showthread.php?t=257448&page=1&pp=15
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
sequential
PostPosted: Sat Mar 04, 2006 7:58 pm    Post subject: Reply with quote
Yeah ,
His work is good , applied knowledge bad ! The cis is direct port carburation
making your fuel curve uneven at different rpm's, fuel is applied in the quantity dictated by the flap regardless of engine requirement vs load. too much here , too little there etc. I would not give shelf space to a cis system !
928 gts prototype
baby blue engine block
steam in 1,2,3,4 sometimes
cold star issues while on stands
112 whp with new 4 valve head and MIS 2
dpw928
PostPosted: Sun Mar 05, 2006 8:58 am    Post subject: Reply with quote
The shape of the slits on the cylinder wall can be changed at different levels to the fuel ratio at different levels. The 928 (and Mercedes?) distributor have narrow rectangular metering slits. If these were machined to a bowling pin shape the air fuel mixture would be increased at a higher midrange rpm. Also a trapazoid shaped slit would cause a steady A/F ratio increase as the rpms rise. Any changes like this would require recalibration of the orifice at the valves and possible adjustment of the valve spring rate. But yes, the CIS can be machined to provide more fuel on turbo charged engines.
Dennis
81 931 5 sp
78 928 5 sp Silver
sequential
PostPosted: Sun Mar 05, 2006 9:28 am    Post subject: Reply with quote
Dennis
Ohh yeah , i would like to see that , as any turbo will pull that flap wide open at peak boost in the mids where it i will be too rich causing excessive lag,
The flap does not open due to rpm but by load causing too much , here not enough there etc. but mostly the high fuel pressure needed to run a cis system limits flow so big HP numbers are out the window.
unless you are happy with 450 to 500 out of a v8 engine, just don't leave the house or venture any where near So. FLA you will not be happy.
928 gts prototype
dpw928
PostPosted: Sun Mar 05, 2006 9:54 am    Post subject: Reply with quote
The flap opens due to air movement, not boost pressure. My concern was the delivery of extra fuel due to the pressure on the distributor piston, but this proved not to be true on the converted engines.
Dennis
81 931 5 sp
78 928 5 sp Silver
sequential
PostPosted: Sun Mar 05, 2006 1:28 pm    Post subject: Reply with quote
Dennis
Dennis not trying to be rude here , but where is the little itty bitty turbo sucking air from to make boost pressure ! ohh yes that 's right from the air flow meter and what causes the air flow meter to go WO , that's right the load!
Ok , so now we have WOT , full load , air flap wide open injectors spraying for all it's worth and the engine is at 3000 rpm , guess what , turbo lag due to being overly rich and boom now full boost 7000 rpm now what happens lean mixture , now engine goes boom for the last time.
because if you set the system to produce a rich mixture at 7000 it will be too rich at 3000 rpm, et al.
My point the CIS cannot fuel any engine correctly based on load vs rpm and mostly it is for low power application at best.
928 gts prototype
dpw928
PostPosted: Sun Mar 05, 2006 5:58 pm    Post subject: Reply with quote
You are confusing pressure (boost) with velocity (air movement). The sensor plate is only opening dependant upon how much air actually enters the cylinders regardless of boost/pressure in the intake. I was suspicious also, but there are supercharger boosted 928's running with this configuration. Check the archives on the Rennlist 928 forum.
Dennis
81 931 5 sp
78 928 5 sp Silver
sequential
PostPosted: Mon Mar 06, 2006 1:14 am    Post subject: Reply with quote
Dennis
I'm not confusing anything dennis and you are getting into semantics , the more boost the more air the more the sensor plate moves , you have not done one of these on a dyno pull to see the plate movement , the sensor plate is load dependant and the plate movement is very much dependant on boost pressure or how much thereof, anyway anyone running a cis system for a turbo application is behind the plate , so to speak pun intended.
928 gts prototype
dpw928
PostPosted: Mon Mar 06, 2006 1:33 am    Post subject: Reply with quote
No semantics here, just physics. Additionally, the air sensor plate has counter (control) pressure of 3 to 3.5 bar pushing it closed unless there is air movement. BTW I posted the link for the guys inquiring about the 928 fuel distributors on the 931 GT's. If you don't think boosting a CIS will work, tell it to the guys on Rennlist that are already supercharging them.
Dennis
81 931 5 sp
78 928 5 sp Silver
sequential
PostPosted: Mon Mar 06, 2006 2:19 am    Post subject: Reply with quote
Dennis
Dennis if you are trying to argue the merits of CIS ok
Merits : blah .......
ok now the demerits of CIS
___blah , blah , blah ,blah, to infinity
1978 - Turbo Charged my FIrst VW Scirroco CIS System ( 14.7 et's )
1979 - Started to mod said CIS system via control pressure mods.
1980-82 - CIS mods with larger injectors along with euro boost reference control pressure regulator.13.2 et's starting doing callaway systems on BMW's along with VW's
1982- Had enough CIS know how on anything that had one,spent many nites wide eyed , knowing there had to be a better way, Did the Bosch school deal , had the books made the jobs work but aaaaggghhh.
84-86 931 turbo time and yes we did the v-8 mod on the 924 twenty years ago ( mercedes fuel head 450 sel ) played played , played .
88- present EFI wow! Programmable EFI systems CIS spat - pooh, pooh
spit, dunk , Germany's way of getting back at the west for WW1 and 2
So please , i do not need to be taught OR LECTURED ON anything REGARDING CIS and i don't care who is using it , in 2006 it does not change the limitations on the system and yes A 928 with cis with turbo 1979 , been there done that ! So now 20 odd years later , someone is turbocharging a cis 928 and i'm to be impressed ! well i like hot rodders and if that is what they are doing then i' m happy for them , but that does not change the demerits of the CIS and i'm not telling them not to turbocharge there 928 with CIS , just stating a fact that in 06 there is mucho EFI systems to choose from at all levels.
And remember the cis is all about system pressure, THIS IS WHY YOUR HP IS LIMITED WITH IT TRYING TO MAINTAIN 5 BAR PLUS FUEL PRESSURE
WHILE REFERENCING BOOST, IS WELL, less move on this is starting to get winded, i'm sure you are happy working with the CIS system Dennis
best of luck and for those wanting to do the v8 mod on a cis system they will have fun, but the money would be better spent going EFI.
928 gts prototype
dpw928
PostPosted: Mon Mar 06, 2006 4:17 am    Post subject: Reply with quote
Since when is discussing the operation of the CIS system considered to be arguing its merits?
I posted the link for the guys wanting to convert an engine to the GT version. If you have a problem with the guys on the 928 forum boosting a CIS system why aren't you over there telling them it won't work? Before you post there I would recommend you do your homework.
Dennis
81 931 5 sp
78 928 5 sp Silver
sequential
PostPosted: Mon Mar 06, 2006 5:27 am    Post subject: Reply with quote
Dennis
Dennis
That 's funny , when does stating that a CIS system is a waste of time on a 924 forum , get's me involved with turbo 928's on the rennlist leading to homework. what's next a carburator expert who profile's his jets .Ha. Ha, HA, I mean after suggesting that there are guys on the 928 forum using the CIS system , stupid of me to think it had your approval, as to me having a problem with 928 guys boosting a CIS car never said i did and frankly don't care, I just said it was not worth the time to invest into a cis system because the full benefit's of turbocharging a 928 would not be realised that way. A Turbocharged 928 should /will be a fast car it is a shame to waste time with the CIS on it..
As for my homework Mrs Robinson said it was not due until march 7th
let me know if it is different , don't want to be late.
928 gts prototype
PostPosted: Mon Mar 06, 2006 5:57 am    Post subject: Reply with quote
As my mom once said after she went to mow the new neighbors' small back yard while they were off on an emergency trip, only to have fuel spill out on the grass, killing it while filling because the fuel line on their mower was loose, "Well, no good deed goes unpunished...".
dpw928
PostPosted: Mon Mar 06, 2006 7:13 am    Post subject: Reply with quote
Smoothie,
Amen to that!!!
Dennis
81 931 5 sp
78 928 5 sp Silver
helowrench
PostPosted: Tue Mar 07, 2006 4:50 am    Post subject: Reply with quote
sequential,
What they are trying to get across is,
You ahev said your piece, we can tell that you do not like CIS.
okay done.
Leave those of us that DO want to work with it to our discussion.
thanks
Rob
