Chrenan
Posted: Thu May 01, 2003 1:58 pm Post subject: Brake Lights |
Hello Everyone,
I was changing a tail light lens this evening and I learned my brake lights don't work (don't worry, I haven't been on the road with this problem).
The indicator, marker and reverse lights all work fine. However, the left and right brake light won't come on when I step on the brake. The bulbs are fine, I swapped them out with ones I know work. I cleaned the connection plates to the bulbs as well, no luck.
I find it funny that both brake lights don't work. Could it be a problem with the brake light pressure switches on the master cylinder? If so is this something an amateur can diagnose and fix?
Could it be a fuse problem? The Haynes manual is none to helpful on this issue.
Any tips and tricks from te pros would be appreciated...
Thanks,
Chrenan _________________ 1987 951 - M193 Version for Japan |
Posted: Thu May 01, 2003 6:37 pm Post subject: |
Check fuse 6. If that's blown your headlights won't pop up.
It's unlikely to be the master cylinder pressure switches. Any problem there should cause the brake warning light to come on. The switches are joined before they go to the brake lights so they'd both have to fail for the lights not to work.
Drag out the Haynes and the multimeter and look up the wiring diagram for the '79/80. It's a very simple circuit. Measure the voltage (with the brake pedal pressed) at both the red/white and black/red wires coming from the master cylinder switches. If you get 12v there check at the connector near the left rear lights which connects a black/red wire to two red/black wires then at the lights. _________________ 1979 924 (Gone to a better place)
kabok
Joined: 25 Jan 2003 Posts: 179 Location: Ft. Collins, CO
Posted: Fri May 02, 2003 3:22 am Post subject: |
| I would check the fuse before looking at the brake light switch. Here's a way to find if the light switch is the problem. Take the light switch connections off and figure out which one is the live and which one is the by pass ground. If you connect these two with a wire, the brake lights should come on. I am not sure which pin numbers are which. Look at Haynes for this. |
Posted: Fri May 02, 2003 3:26 am Post subject: |
check to make sure there isn't alot of corrosion around the bulbs not allowing electricity to pass through _________________ 3 928s, |
Chrenan
Posted: Fri May 02, 2003 3:41 am Post subject: |
Should I be looking at Fuse 6? Peter suggests if this fuse is a problem then the headlights won't raise, but the headlights go up and down and turn on with no problems... _________________ 1987 951 - M193 Version for Japan |
Roger
Posted: Fri May 02, 2003 4:57 am Post subject: |
First check with a know good bulb. Second check to make sure you have 12 volts and a good ground at the bulb holder. Then check your fuses. _________________ 1981 924 NA
Posted: Fri May 02, 2003 9:53 am Post subject: |
the brake lights are powered via fuse 6 same as the headlight motor. The power to fuse 6 and then on to the master cylinder switches is unswitched (not switched on by the ignition key) so put a brick on the brake pedal and start checking for voltages.
One of those $2 auto wiring test lights would be quickest. The ones with the pin that pierces the wire insulation and the alligator clip for earth.
I'd suggest starting at the master cylinder. and working towards the rear until the light goes out. Testing with a light is best because with corroded connectors a multimeter can still read 12 - 13v but there's not enough current (amps) to actually light a globe. _________________ 1979 924 (Gone to a better place)
numbbers
Posted: Fri May 02, 2003 10:50 am Post subject: |
Well Peter, my brake lights quite working on my '80 and it turned out to be the pressure switch on my master cylinder. The brake warning light never came on. _________________ 1980 924 Turbo |
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Fri May 02, 2003 12:47 pm Post subject: |
| numbbers wrote: | | it turned out to be the pressure switch on my master cylinder. The brake warning light never came on. |
Same happened to mine. Easy to diagnose and fix tho  _________________ '86 944 |
Posted: Fri May 02, 2003 12:49 pm Post subject: |
OK. That was my reading of the wiring diagrams - that a master cylinder switch failure would light the brake-check light (unless both switches failed). Learn something every day.  _________________ 1979 924 (Gone to a better place)
Chrenan
Posted: Sat May 03, 2003 12:39 am Post subject: |
Thanks for the help everyone,
I figured it out last night. Got out the multimeter and had two hours of fun with the 924 wiring. Turned out the little wire underneath the emergency brake handle was disconnected from its switch. Without this the brake warning light on the instrument panel and the brake lights would not work. Reconnected the wire and all is well. In the process I also scraped down all the grounds and connectors I came across and checked and swapped all bulbs where needed and fixed all four corner lights as well. Now the car lights up like a Christmas tree.
During my adventures in wiring land I noticed the PO had inserted a 25 A fuse in a slot that should have had a 8 A fuse. I swapped it for an 8 A fuse. What is the danger of having a 25 A fuse in there instead (probably a bit of a dumb question).
On another note, was the 924 wiring setup designed at the peak of Oktoberfest?
Posted: Sat May 03, 2003 1:18 am Post subject: |
Fuse ratings and wire sizes are chosen based on the amp draw of the components on a circuit and the fuses are there to protect the wiring from going up in flames in case of a short circuit or failing component that might cause an increased amp draw. If nothing happened to fry while you had the 25A fuse in there, then there's no problem. _________________ "..it's made in Germany. You know the Germans always make good stuff."
numbbers
Posted: Sat May 03, 2003 9:43 am Post subject: |
Was the 924 wiring setup designed at the peak of Oktoberfest?
Well, the Germans design great mechanical things, but they are not known for their electronics. Ever own an Grundig stereo?[/quote] _________________ 1980 924 Turbo |
Posted: Sat May 03, 2003 10:13 am Post subject: |
congratulations! The hardest part about fixing electrical problems is actually starting.
Really, German wiring is not that bad, especially when you compare it to Italian or British wiring of the same period. The only wiring that's any good after 20 years is Japanese because they totally over-engineer and keep it simple. _________________ 1979 924 (Gone to a better place)
HahnW
Posted: Sat May 03, 2003 10:47 am Post subject: |
My first post in about 2 years, but I have the same problem.
I determined that both pressure switches are faulty (bridged the contacts on the plug with a paper clip and the brake lights came right on), but I am afraid to remove the switches in case the brake fluid comes spewing out and I will have to bleed the system.
How exactly do you replace the brake light pressure switches?
Do you need to bleed the brakes afterwards?
Also, where do I buy new pressure switches? _________________ Onyx Green Metallic 1980 924NA
5-Bolt, 5-Speed |
