thickness brake discs
ring931
PostPosted: Sat Feb 17, 2007 6:45 pm    Post subject: thickness brake discs Reply with quote
What is the thickness of the front rotors of a 931 with the 5-bolt setup ?
And when should they be replaced, i.e. minimum thickness ?
And the rear discs ?
PostPosted: Sun Feb 18, 2007 10:36 am    Post subject: Reply with quote
According to the little Technical Specification book when new they are 20.5mm (front) and 20.0 (rear). The "Minimum Brake disk thickness after reworking" is 19.1mm (front) and 19.2 (rear).
ring931
PostPosted: Mon Feb 19, 2007 7:38 am    Post subject: Reply with quote
Peter_in_AU, thanx for the info !
Does somebody know the original thickness of the brake pads ?
PostPosted: Wed Feb 21, 2007 8:18 am    Post subject: Reply with quote
Info is also hopefully stamped on the rotors themselves. . .
