NikDev
Posted: Sun Jun 25, 2006 9:41 am Post subject: Engine swamp 79 -> 84 |
Hello
I have a 79 mod Na, the engine is bad... I have found crashed 84 mod. who has a good engine.
Is there any differences between a 84 and 79 mod?
Besides from K-jetronic Cis on the 79 mod. And Lambda based system on the 84 mod.
Can i still use the mechanical K-jetronic?
Nikolai D. _________________ x79 924 |
Posted: Sun Jun 25, 2006 10:45 am Post subject: |
Use the long block + from the crashed 84 924 (engine block with head, intake, exhaust manifold, alternator, and ac compressor) with the fuel injection, and ignition distributor from your 79.
The 84 has better (more advanced fuel injection, emissions, and ignition systems) but would require you to move the complete systems from the crashed car to yours to be able to use any parts from the newer systems. |
Posted: Sun Jun 25, 2006 12:39 pm Post subject: |
Over here if you put a later model engine in a car all the emission control stuff has to go in as well that goes with the new engine. _________________ Porsche 924 1984 (UK import) NA
Posted: Sun Jun 25, 2006 1:23 pm Post subject: |
Legally, that's how in works in the US also.
BUT, who is going to be able to tell, if all you use is the long block? |
NikDev
Posted: Thu Jul 20, 2006 7:54 pm Post subject: |
Progress...
The parts car:
Its actually a good engine, new clutch\starter etc..
Most gone
Homemade support to the axle:
I am using this to lift out the engine:
Gone:
And so i had to start on the other car:
The crossmeber and steering has to go down, so i have space to lift and drag the engine
Ready for lift:
I am going to use fuel injection and ignition distributor from my 79mod. _________________ x79 924
NikDev
Posted: Mon Jul 24, 2006 4:50 am Post subject: |
Switching of fuel lines and wiring harness in progress.. The only difference was the oil pressure switch
Some hours later; The 84` engine is in place in my 79`924
Almost ready for start, i have also taken the distributor from the 79`engine.
Tomorrow i am going to try start it  _________________ x79 924 |
NikDev
Posted: Wed Jul 26, 2006 1:36 am Post subject: |
And it started
But i need to adjust the timing, can i do that without timing light? _________________ x79 924 |
seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Wed Jul 26, 2006 2:27 am Post subject: |
| NikDev wrote: | And it started
But i need to adjust the timing, can i do that without timing light? |
not really... I guess you could get her running roughly without.... _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
NikDev
Posted: Wed Jul 26, 2006 2:34 am Post subject: |
| seanski44 wrote: |
not really... I guess you could get her running roughly without.... |
I have got her running roughly, but she will not idle... _________________ x79 924 |
seanski44
Posted: Wed Jul 26, 2006 2:58 am Post subject: |
| NikDev wrote: | | seanski44 wrote: |
I have got her running roughly, but she will not idle... |
mixture OK? - otherwise, the distributor has a vacuum advance doesn't it? - is this connected? - not sure whether this would affect it - is the vacuum pipe connected, will it advance the dissy?
what about the idle screw, have you adjusted it? _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
Posted: Wed Jul 26, 2006 3:14 am Post subject: |
When you replaced the distributor, how did you set the timing?
Rough/Initial timing would be to set the crankshaft TDC (top dead center), with the camshaft at the marks (pointer on the valve cover pointing to the mark on the back of the camshaft timing gear) and the distributor to fire on the #1 cylinder (rotor pointing to the mark on the top edge of the distributor housing that is visible when the distributor cap is removed).
After getting the engine running at TDC, you can advance the distributor slightly, as the Euro engines are specc'd to run at 10 degrees BTDC. Not too much as you don't want to cause engine knock (pre-detonation) due to too much timing advance.
You will need a timing light to finalize your ignition timing, but this should get you running. |
NikDev
Posted: Sun Jul 30, 2006 12:15 am Post subject: |
Today i got a timing light home and i fine tuned it, and the car runs great now
Thanks  _________________ x79 924 |
