cams made in england?
seanski44
PostPosted: Tue Jul 11, 2006 12:56 am    Post subject: cams made in england? Reply with quote
Was under the bonnet (hood) and noticed that my cam had ENGLAND stamped on it - are they all made in England? or has mine been frankensteined before!
1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD
Chrenan
PostPosted: Tue Jul 11, 2006 2:16 am    Post subject: Reply with quote
Could be a Piper cam.
tux
PostPosted: Tue Jul 11, 2006 3:31 am    Post subject: Reply with quote
Indeed. An aftermarket cam is about all I can come up with too. Though I guess its not beyond the bounds of possibility that the OEM part was manufactured in the UK. After all, Britain still had a manufacturing industry back then!
Pete
Merlin Guards Red 1985 N/A
seanski44
PostPosted: Tue Jul 11, 2006 3:42 am    Post subject: Reply with quote
well, this cam came from a 931 my brother and I bought for bits.. perhaps it had been piper-ed! (the last MOT on that parts car was mid nineties!)
1992 968 lux SOLD
John Brown
PostPosted: Tue Jul 11, 2006 3:57 am    Post subject: Reply with quote
The drive sprocket is not part of the cam and normally is not supplied with the cam. So a guess would be that the part is UK manufacture or specific to UK applications. Anyone check for different part numbers?
John
80 931 - #931 44Cup
99 Escalade - tows track cars
seanski44
PostPosted: Tue Jul 11, 2006 4:00 am    Post subject: Reply with quote
well, that's the bizzarre thing, I checked that the turbo cam was the same as the na cam before swapping them, but I don't believe I looked at the part num on the cam itself. hmm, is that it in the pic?
1992 968 lux SOLD
PostPosted: Tue Jul 11, 2006 8:13 am    Post subject: Reply with quote
The cam timing wheel is separate to the cam.
John Brown
PostPosted: Tue Jul 11, 2006 11:44 am    Post subject: Reply with quote
May be beating a dead horse; but just to clarify. The picture is not of the cam. The part with 'England' is the sprocket or drive wheel. Remove the bolt and pull it off.
And, yes, the cam is the same for na and turbo alike.
John
80 931 - #931 44Cup
PostPosted: Tue Jul 11, 2006 5:09 pm    Post subject: Reply with quote
PET shows the cam sprocket part number for an '85 924 (yours is an '86, right, Sean?) as 049 109 111 C.
The number stamped on your spocket shows it's an earlier 'A' variant and so must pre-date you car by quite a bit.
seanski44
PostPosted: Tue Jul 11, 2006 7:09 pm    Post subject: Reply with quote
no, you're not beating a dead horse, I got it the first time!
and yes, I know the cam is the same.
and apologies for the messed up terminology. I was, of course, referring to the cam sprocket.
I won't remove the bolt and pull it off as it works a treat, but thanks anyway. It was merely an observation - I have far too much to be getting on with, taking a pic of it was a brief respite in the number of tasks I'm up to my neck in!
1992 968 lux SOLD
seanski44
PostPosted: Tue Jul 11, 2006 7:11 pm    Post subject: Reply with quote
yeah, as mentioned it came from an '81 turbo, as unfortunately the sprocket on my cam which was attached to my cylinder head previously was bent... (sprocket wheel appeared to wobble) - due to this and to the fact that I had the problem with the tappet, I simply switched the cam and sprocket together from the 931 head. (after having checked PET for compatibility of course)
1992 968 lux SOLD
