sunroof motor-only reverse?
nodakporsche
PostPosted: Sat Jul 01, 2006 7:17 am    Post subject: sunroof motor-only reverse? Reply with quote
Hello again guys. Im back for more of your expert advise. Well I dug into the sunroof "stuff". One of the gears was completely stripped. Thats an easy enough fix. The other problem Im having is that the motor only goes one direction. It only pulls out the cable. It wont go into the housing. Im assuming the motor is okay and it is either a switch or sensor or relay problem. I dont even know where to start. Any advise would be appreciated. Also, is ebay the best place to buy a left wind deflector hinge. Thanks again guys.
nodakporsche
PostPosted: Fri Jul 07, 2006 5:50 am    Post subject: Reply with quote
nobody has any ideas?
PostPosted: Fri Jul 07, 2006 6:09 am    Post subject: Reply with quote
All 924 cars with sunroofs (with the exception of the 87-88 924S) came with manually operated sunroofs.
You need to ask your questions about power operated sunroofs on either the RennList, or Pelican Message Boards.
Raceboy
PostPosted: Fri Jul 07, 2006 4:15 pm    Post subject: Reply with quote
Gohim, that's where you're wrong. My '84 924 has electrically operated sunroof.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
seanski44
PostPosted: Fri Jul 07, 2006 4:51 pm    Post subject: Reply with quote
my '85 924 has an electric sunroof also.
1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD
PostPosted: Fri Jul 07, 2006 5:27 pm    Post subject: Reply with quote
And mine.
With regards to you question I'd replace switch then the relay.
PostPosted: Fri Jul 07, 2006 5:31 pm    Post subject: Reply with quote
Then that would be a clear difference between the U.S. market 924 and cars made after Porsche stopped importing them to the U.S.
I have inspected at least a dozen U.S. spec cars that were privately imported between 1983 and 1985 (model years 83-85), and while all of them had sunroofs, none of them were powered.
Still, you will get better advise on the care and repair of powered roofs where 944 people gather. There just aren't that many people on this board with cars that have powered sunroofs, compared to the other sites that I mentioned.
seanski44
PostPosted: Fri Jul 07, 2006 5:53 pm    Post subject: Reply with quote
also, could it be the microswitch? - there's a microswitch located in the centre of the headlining, in front of the sunroof. Its there to detect whether the roof is in place or not, the idea is that the prong at the centre of the front of the removable panel depresses the switch when the roof is in. These microswitches do fail - but its possible I guess that this decides which direction your motor pulls? Not entirely sure, but worth checking out...
1992 968 lux SOLD
PostPosted: Fri Jul 07, 2006 6:24 pm    Post subject: Reply with quote
The motor also has 2 microswitches.
Check operation of all the switches using a meter and that you are getting power to the relays.
PostPosted: Sat Jul 08, 2006 12:07 am    Post subject: Reply with quote
Here's the best info I've found on our sunroofs:
http://www.clarks-garage.com/shop-manual/body-03.htm
http://www.clarks-garage.com/shop-manual/elect-18.htm
timstar92404
PostPosted: Sun Jul 09, 2006 8:50 pm    Post subject: Reply with quote
If you don't care about having an electric sunroof ( I don't really care) you can convert it to a manual sunroof which I've heard is pretty easy, you just replace the rear raising arms with manual latches from a manual sunroof they are suppose to just fit on the electric roof.
78 924 sold.
85.5 944
