Porscheaddiction
Joined: 03 Nov 2002 Posts: 431 Location: Cornwall, Ont, Canada
Posted: Sun Jul 09, 2006 5:21 am Post subject: Belt changes how often? |
Ok guys just had the misfortune of the alt/waterpump snaping the car is fine with a new belt tho.
How often in years and or miles does everyone change their belts?
I would like to eliminate the possibilty of a belt snap from milage/time fatigue.
Chris _________________ 1981 924 NA (Restoring mode)
1984 928S (Enjoying the driving season) |
tux
Joined: 02 Jul 2006 Posts: 133 Location: Nottingham UK
Posted: Sun Jul 09, 2006 6:05 am Post subject: |
Not Porsche specific, but when it comes to timing/cambelts I tend to find the recommended replacement interval and halve it. If the interval is 40000m I will change it out at 20000. Generally not worth the risk, though I am led to believe the 2 litre Audi unit is a "safe" motor? Timewise I would say 24 months is plenty long enough for a rubber belt to serve.
With less critical belts, I tend to go on visual appearance. If they look OK I am prepared to give them the benefit of the doubt.
Just my opinion mind!  _________________ Pete
Merlin Guards Red 1985 N/A |
Posted: Sun Jul 09, 2006 6:21 am Post subject: |
On the two liter motors, if you change the timing belt and tensioner every 5 years or 60,000 miles (which ever comes first), you should be fine.
I never reuse a timing belt that's more than 6 months old, if you have to take it off, replace it. _________________ White 87 924S "Ghost"
Porscheaddiction
Posted: Sun Jul 09, 2006 6:22 am Post subject: |
not sure how safe it is its, normally yes however if rework has been done to the head its possible are beloved non-inference engine has become interference type.
Thanks for the heads up.
So two years is long enough on the alt/water pump belt?
I keep records of everything I do dates/and work done so thats why the questions on intervals so I can avoid things like this happening again.
Chris. _________________ 1981 924 NA (Restoring mode)
Posted: Sun Jul 09, 2006 6:57 am Post subject: |
An alternator belt that's properly adjusted, running on aligned pulleys, and driving an alternator that's not wobbling should easily last 5 years. _________________ White 87 924S "Ghost"
tux
Posted: Sun Jul 09, 2006 10:09 pm Post subject: |
I do tend to err on the side of caution! I guess my theories are based on paranoia, but having had several timing belts go on me in the past I just won't risk it! Alternator drive belts etc seem to go at the least opportune moment too so I tend to change them regularly as they are so cheap. _________________ Pete
OutOfTheBox
Posted: Mon Jul 10, 2006 1:21 am Post subject: |
I beleive that having correctly tensioned belts is more important than their age.
The first motor I rebuilt, I overtightened the NEW cam belt, and it lasted about 2 weeks, when I stopped the car it was a few threads hanging on.
I have also had premature belt failure as a result of "nicks" on the pulleys, and worn alternator mountings. |
dpw928
Posted: Mon Jul 10, 2006 3:45 am Post subject: |
Also, overtightened cam journals can cause premature belt failure. BTDT
78 928 5 sp Silver
78 928 AT Euro Black |
Posted: Mon Jul 10, 2006 7:27 am Post subject: |
Mine survived for five years (probably longer, I don't know when it was last changed before we did it). But that's doing ultra-low miles/year.
We've got a good climate for cars, though. And mine was always garaged. Probably helps a bit. _________________ '80 924 Turbo |
