clutch malfunction
robermar
PostPosted: Mon Jul 10, 2006 7:59 am    Post subject: clutch malfunction Reply with quote
Has anyone ever had the clutch to go out when the car is not in use? I parked my '77 924 with an electrical problem. Two weeks later, when I got around to fixing the wiring, the clutch was out! Feels like plenty of pedal pressure, the clutch arm is working, but it will not engage! Help!!
PostPosted: Mon Jul 10, 2006 8:03 am    Post subject: Reply with quote
Please describe the problem in more detail.
Are you saying it is slipping, or will it not disengage?
robermar
PostPosted: Mon Jul 10, 2006 8:11 am    Post subject: Reply with quote
It will not disengage at all....can't crank it in gear with the clutch mashed, can't shift into gear with the engine running....
Chrenan
PostPosted: Mon Jul 10, 2006 8:16 am    Post subject: Reply with quote
Could the clutch disk have "frozen" itself to the flywheel?
robermar
PostPosted: Mon Jul 10, 2006 8:30 am    Post subject: Reply with quote
That's what I'm thinking, but how can I "unfreeze" it without a major ordeal? any ideas?
Chrenan
PostPosted: Mon Jul 10, 2006 8:32 am    Post subject: Reply with quote
Get under the car, remove the inspection plate on the rear of the bell-housing and lightly tap the pressure plate and clutch disk with a rubber mallet. Might do the trick.
tux
PostPosted: Mon Jul 10, 2006 8:34 am    Post subject: Reply with quote
I guess you could try wedging down the clutch pedal and leaving it for a while. If its not too badly stuck it may "pop" after a while.
Pete
Merlin Guards Red 1985 N/A
robermar
PostPosted: Mon Jul 10, 2006 8:38 am    Post subject: Reply with quote
I've tapped on the pressure plate, and I now have the pedal wedged down....cross your fingers....
I have a new clutch and pressure plate, but really don't have the time to go into it right now... with gas prices the way they are, I really miss the 40mpg my 924 gets...
tux
PostPosted: Mon Jul 10, 2006 9:06 am    Post subject: Reply with quote
Fingers crossed here!
Can you really get 40mpg from your 924? I wish I could!
Pete
D Hook
PostPosted: Mon Jul 10, 2006 10:05 am    Post subject: Reply with quote
I had the same thing happen when I didn't drive the car for about a year. A little judicious jostling with the starter (car in gear) and it finally popped free. YMMV.
'80 924 n/a SOLD
PostPosted: Mon Jul 10, 2006 10:31 am    Post subject: Reply with quote
Try putting the car in high gear, then push the brake and clutch pedal hard and hold them down.
Then crank the starter.
robermar
PostPosted: Mon Jul 10, 2006 10:47 am    Post subject: Reply with quote
WHEEWWW! FINALLY!!! I tried all the above suggestions, then finally got angry and just started trying to jam it in high gear with the clutch down and the engine running, and it popped in after many profanities with interjected pleas to heaven. I probably wouldn't recommend the aforementioned procedure, especially the profanities!!
Jaf
PostPosted: Mon Jul 10, 2006 7:53 pm    Post subject: Reply with quote
I was getting close to that, about 38. But that was on 98ron leaded. Might lose a bit with the crappy fuel. Although don't they have lower ron in the states?
Boy am I glad my clutch didn't stick. What a palaver.
1978 924na
