skemcin
Joined: 02 Sep 2003 Posts: 1284 Location: Plainfield, IL
Posted: Sun Aug 06, 2006 12:52 pm Post subject: brake job |
well, I guess I'm no longer a virgin. I completed my first "real" repair work on my 924. I've done odds and ends, but this brake job required a little more than just doing this or that.
it started two weeks ago when I saw a puddle at both my rear wheels. Suspecting it was the wheel cylinders, I removed the drums to inspect and sure enough it was. So, on both sides, I replaced the wheel cylinder, replaced the shoes, free'd up my parking brake (except coming from the cab), repacked the wheel bearing (while I was there), and discovered the two little wholes in the rear drim plate that allows you to adjust the shoes without having to take the drums off.
This was much easier having the use of a lift at my buddies dealership. Next, order and install the Bilsteins. _________________ 924.org (no time to complete)
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power |
Chrenan
Posted: Sun Aug 06, 2006 1:59 pm Post subject: |
I've done both shocks and brakes, the shocks are the easier job by far! _________________ 1987 951 - M193 Version for Japan |
skemcin
Posted: Sun Aug 06, 2006 2:25 pm Post subject: |
| Chrenan wrote: | | I've done both shocks and brakes, the shocks are the easier job by far! | thanks - I did take a look at the set up while I had the car up, the rear does seem fair straight forward and easily accessible - haven;t looked at the front yet. _________________ 924.org (no time to complete)
Chrenan
Posted: Mon Aug 07, 2006 12:58 am Post subject: |
Yes, rear is 4 bolts, it might take you longer to jack up the rear than it does for you to change the shocks. The front is more involved. If you're replacing the bushings on the control arms (which you should) it is easier to take them somewhere with a large press to have the bushings removed and installed. _________________ 1987 951 - M193 Version for Japan |
skemcin
Posted: Mon Aug 07, 2006 4:37 am Post subject: |
| Chrenan wrote: | | Yes, rear is 4 bolts, it might take you longer to jack up the rear than it does for you to change the shocks. The front is more involved. If you're replacing the bushings on the control arms (which you should) it is easier to take them somewhere with a large press to have the bushings removed and installed. | Are you talking about getting someone to perss the bushings in here:
Chrenan
Posted: Mon Aug 07, 2006 4:44 am Post subject: |
Those are the ones. _________________ 1987 951 - M193 Version for Japan |
skemcin
Posted: Mon Aug 07, 2006 12:27 pm Post subject: |
great , thanks _________________ 924.org (no time to complete)
