Vooley
Joined: 28 Jan 2006 Posts: 14 Location: Surrey, United Kingdom
Posted: Mon Jul 24, 2006 9:27 am Post subject: Cant start car :( |
Had my 924S for 6 months nearly and love it to bits, but in the last few days i cant start it! The starter motor is turning over but the engine wont even start to rev. Im getting a good oil pressure when i try to start it and the spark plugs are all fine. Strange thing is it can be bump started with no problem....can any1 help? Thanks for your time gents  |
Posted: Mon Jul 24, 2006 10:17 am Post subject: |
Your ignition switch may not be supplying power when cranking.
Or there is a break in the cct _________________ Porsche 924 1984 (UK import) NA
Vooley
Posted: Wed Jul 26, 2006 1:23 pm Post subject: |
| dont hate me but what is a CCT? |
Posted: Wed Jul 26, 2006 3:35 pm Post subject: |
Abbreviation for circuit. _________________ Porsche 924 1984 (UK import) NA
seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Wed Jul 26, 2006 3:49 pm Post subject: |
is there an immobiliser fitted to the car? _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
Vooley
Posted: Thu Jul 27, 2006 1:20 am Post subject: |
| Nope, no immobiliser. So how do i check for these things? |
Posted: Thu Jul 27, 2006 6:09 am Post subject: |
ign switch or the booster wire off the starter (circuit 15) has come off. _________________ 3 928s, |
Posted: Thu Jul 27, 2006 7:56 am Post subject: |
Try a new DME relay, most of us keep a spare in the glove box. _________________ White 87 924S "Ghost"
Posted: Thu Jul 27, 2006 8:04 am Post subject: |
| Paul wrote: | | Try a new DME relay, most of us keep a spare in the glove box. |
But then it wouldn't bump start either. _________________ Porsche 924 1984 (UK import) NA
Posted: Thu Jul 27, 2006 2:45 pm Post subject: |
What does bump mean?
Is this jumping the car or pushing it and popping the clutch?
In either case, the DME relay may be seeing higher voltage, which may persuade it to close. _________________ White 87 924S "Ghost"
Posted: Thu Jul 27, 2006 4:27 pm Post subject: |
I assume push start and dropping the clutch. _________________ Porsche 924 1984 (UK import) NA
Vooley
Posted: Sun Aug 06, 2006 3:38 am Post subject: |
| Ok there is no spark when i take the plug out, rest it against the block and start it. If the car is bump started its possible to turn her off and start her with the keys. I tried this after an few hours and it would still start, but after leaving it overnight it wouldnt. Does that reduce the number of possibilites? |
Vooley
Posted: Sun Aug 06, 2006 3:41 am Post subject: |
| Also, when i try and start it the headlights go out |
Posted: Sun Aug 06, 2006 9:10 am Post subject: |
| Vooley wrote: | | Also, when i try and start it the headlights go out |
That's usually a battery, connection, earthing or starter problem. _________________ Porsche 924 1984 (UK import) NA
OutOfTheBox
Posted: Mon Aug 07, 2006 8:34 am Post subject: |
| Quote: | | Also, when i try and start it the headlights go out |
Why are you trying to start it with the headlights on ?
Does the starter motor turn it over quickly ?
Try boosting it with another battery, and some GOOD quality jumper cables.
Eliminate the battery before you go pulling your fuse box apart.
When I've had batteries die on me, the starter turns the motor, but not enough to fire her up. |
