EBS bushings fo VW pistons
leadfoot
PostPosted: Thu Aug 17, 2006 2:07 pm    Post subject: EBS bushings fo VW pistons Reply with quote
I purchased some 22mm wrist pin bushings to use with my VW pistons although it seem that they do no fit the pins... can anyone confirm whether machining is needed to fit the parts together...??
Also the OD of the bushing seems to be about 27mm... So I am assuming that the bushings need to be turned down to fit the stock rods...
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Thu Aug 17, 2006 9:55 pm    Post subject: Reply with quote
Hmmm... I had mine installed by a machine shop, let them deal with that.
Are there already bushings in there which need to be removed first?
leadfoot
PostPosted: Fri Aug 18, 2006 7:10 pm    Post subject: Reply with quote
I don't think so... I've never pulled apart the block before.
Basically it's a bushing to make up the slack between the stock 24mm pin and the new VW 22mm pin...
It just suprised me that the bushings were 27mm OD, I would have thought they were closer to 24mm OD for the stock rod...
What I'm trying to work out is if I have the wrong bushing, or whether I have to increase the rod ID and reduce the bushing OD to get an approximate match....basically what to take off where...
I'm definately with you on this one Vaughn and I may just dump it in the machine shops lap, just hoping I might at least give them some info on what other people have done first...
Leadfoot
Raceboy
PostPosted: Fri Aug 18, 2006 9:12 pm    Post subject: Reply with quote
Stock rods DO have bushings that need to be removed first.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
simsport
PostPosted: Fri Aug 18, 2006 11:13 pm    Post subject: Bushes Reply with quote
I think you have to have them machined and pressed home and then reamed out to fit your small end. I got bushes for the 931 pistons from JE via EBS and thats what we had to do.
AS an aside you also had to mill the side faces of the rods down as the porsche rods are too wide.
All worked fine though.
Cheers
Simon
Blown is always best!
leadfoot
PostPosted: Fri Aug 18, 2006 11:34 pm    Post subject: Reply with quote
thanks guys...
leadfoot
-nick
PostPosted: Sat Aug 19, 2006 12:16 am    Post subject: Reply with quote
The bushings definitely need reamed after being pressed in.
Just a note - the JE pistons require milling the sides of the small end of the rod. The VW pistons leave plenty of space and you don't have to do this.
