air intake modification
billson
PostPosted: Thu Mar 29, 2007 8:28 am    Post subject: air intake modification Reply with quote
Anybody seen/done this modification to the air intake box?
Cooler air would get in instead of air warmed by the engine bay as in the stock set up. But would it really make any difference? Worth cutting your air filter box for?
1983 924 NA
Guards Red
Carrera GT bodykit
Larger VW throttle body
PostPosted: Thu Mar 29, 2007 9:27 am    Post subject: Reply with quote
I have seen this and other variations. Hardly seems worth it unless you've installed a big valve head (along with other mods).
PostPosted: Thu Mar 29, 2007 9:52 am    Post subject: Reply with quote
i dont think that stock 924 is that sensitive to air temperature.
PostPosted: Thu Mar 29, 2007 11:56 am    Post subject: Reply with quote
I dunno... the temp here in Sydney has just dipped this week and yesterday it was about 15C when I was driving to work - my toofah definitely felt like the cooler air was helping.
Dagwood928
PostPosted: Thu Mar 29, 2007 12:04 pm    Post subject: Reply with quote
cooler air is denser air. Doubtful that there would be much in the way of seat of the pants, but it is an improvement. I don't think making the duct out of aluminium flex tubing helps as it soaks up engine heat, and transfering it to the cold air coming in, but plastic may help a bit more. Just my two cents!
Darren
Kenodog
PostPosted: Thu Mar 29, 2007 12:15 pm    Post subject: Reply with quote
On a forced induction vehicle getting 1 hp per 1 deg in temp drop is very doable because you can up the boost. Keep in mind that modern cars have knock sensors in the efi system that will help the computer advance the timing as much as possible thereby making more power. A stock,N/A 924 does not have this luxury so any hp gain is purely due to he physics of denser air as Dagwood said. If you put the car on a dyno with and without i'd say you would be really surprised to see more that 1-2 hp on a stock engine. My $.02
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Min
PostPosted: Thu Mar 29, 2007 2:05 pm    Post subject: Reply with quote
and my .02 is that a dyno is not accurate enough to properly measure a 1-2hp increase. But do enough 1-2hp increases and soon you've got 10hp
Min
Kenodog
PostPosted: Thu Mar 29, 2007 3:16 pm    Post subject: Reply with quote
Sadly, to get that 10 hp comes at the price.
How many of you are willing to pump hundeds of dollars and countless hours in order to make a relic like the too-fa make an extra 10 hp ?
Not to 'dis the cars but there are better ways to get the same perfomance.
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Thu Mar 29, 2007 4:58 pm    Post subject: Reply with quote
We're not talking hundreds of dollars here. An length of tube is under a dollar. If it gains 1 - 2 hp, that's got to be the biggest bang per buck of any mod.
Don't underestimate the benefit of denser air - why do you think intercoolers got invented?
PostPosted: Thu Mar 29, 2007 8:05 pm    Post subject: Reply with quote
"why do you think intercoolers got invented?"
because the chargers heat the shit out of the air. boosted cars have much higher intake air temps. But what the hell i'm gonna try it this weekend and see what happens ! i'm gonna try to do some accurate tests. i have a very accurate system measuring time over 400m or whatever distance and i will try to do some tests.
Vince Ponz
PostPosted: Thu Mar 29, 2007 11:31 pm    Post subject: Reply with quote
Cheap fix.
Spin intake to behind the headlight and put on a K & N filter. Now the heat will not get to the airbox directly over the rad. It cannot hurt at best.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Fri Mar 30, 2007 12:29 am    Post subject: Reply with quote
1) it was a rhetorical question
2) beacuse cooler air is denser, which is the point I was making.
Min
PostPosted: Fri Mar 30, 2007 1:38 am    Post subject: Reply with quote
I think you missed the point of my post entirely. I said that if you do a number of small changes that add 1-2hp they will add up to 10hp. The problem is simply finding easy/cheap things that will increase hp by 1-2 points. Pretty sure that was not a reference to dumping money into our cars to get 10hp.
Min
PostPosted: Fri Mar 30, 2007 3:47 am    Post subject: Reply with quote
sorry Mike i was a lil bit.....heavy minded...woke up with a hangover.
PostPosted: Fri Mar 30, 2007 4:33 pm    Post subject: Reply with quote
It's cool. (not your hangover, I mean )
