trigger-wheels
augidog
PostPosted: Tue Aug 15, 2006 11:22 am    Post subject: trigger-wheels Reply with quote
http://www.trigger-wheels.com/
neat!!!!
I'm wondering if I can use the smaller wheel on the Camshaft gear end to eliminate the mounting problems?
endwrench
PostPosted: Tue Aug 15, 2006 2:22 pm    Post subject: Reply with quote
Good looking stuff but you would need a 72-2 gear for cam mounting assuming you are going EDIS.
Todd
OutOfTheBox
PostPosted: Tue Aug 15, 2006 4:37 pm    Post subject: Reply with quote
I just used a GM wheel, which I cut the centre out of then welded to the back of my front pulley, its very light.
I welded a single peg onto my cam gear, for the cam pickup, for fully sequential.
The ones in your link, look like they might be quite heavy.
PostPosted: Tue Aug 15, 2006 5:13 pm    Post subject: Reply with quote
Got any photos of that?
Kenodog
PostPosted: Thu Aug 17, 2006 2:09 pm    Post subject: Reply with quote
Yeah I like the idea of a ring instead of a wheel.
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
OutOfTheBox
PostPosted: Fri Aug 18, 2006 1:29 am    Post subject: Reply with quote
This trigger wheel is of a GM/OPEL/VAUXHALL Astra
I dont have an aircon, if you do, you will have to mount it differently. The aircon belt is on the inside pulley, alternator on the outside.
The inner and outer ID's matched the Porsche wheel perfectly. I'm not sure if i enlarged the centre ID, to fit the VW I used it on previously.
The adjustment screws are from when I used the wheel on my VW.
It just clears the oil pump housing, and you can mount the sensor in about 10 minutes, because it is level with the 3 bolts, that hold the alternator sub mount.
Raceboy
PostPosted: Fri Aug 18, 2006 5:19 am    Post subject: Reply with quote
Something like I did on my 931, instead I welded to notches to the 931 crank pulley 180 degrees apart. Sensor is also mounted using the alternator sub-mount bolts.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
