Water Heater Vavle
kenaijoe
PostPosted: Thu Aug 17, 2006 10:48 am    Post subject: Water Heater Vavle Reply with quote
Has anyone had the water heater valve replaced by a dealer and if so how much was it? Also...is this something that can be done by a half assed mechanc like me?...thanks....pat
PostPosted: Thu Aug 17, 2006 9:53 pm    Post subject: Reply with quote
I replaced mine myself; pretty easy, since I was already in there replacing the rubber damper (on the automatic - same as replacing a clutch on a stick). That made access real easy; it also was how I found out about it, noticing the leak while I was working on the bellhousing.
The big PITA I believe is just getting access to it; it's just a couple of hose clamps and the cable, once you get to it, right guys? Maybe someone else can tell what needs to be done to get to it...
John Brown
PostPosted: Thu Aug 17, 2006 11:01 pm    Post subject: Reply with quote
It's an easy job.
It's impossible to reach in there to do the easy job.
Don't drop the clip holding the cable to the valve body.
Where (in MO) are you?
John
80 931 - #931 44Cup
99 Escalade - tows track cars
kenaijoe
PostPosted: Fri Aug 18, 2006 11:20 am    Post subject: water heater valve Reply with quote
Thanks....in Knob Noster...where the B2's are at. So...the slider on the console is what moves the valve on and off..is that correct? If so, I'm assuming I can remove the console/radio and all that crap and see the valve from the inside...is that correct?
thanks....pat
kenaijoe
PostPosted: Fri Aug 18, 2006 8:21 pm    Post subject: woohoo...fixed Reply with quote
Thanks guys....printed off the link Peter sent ...found that little bastard and it was just the cable clip.....Nice cold Ac......life is good.....thanks agin and have a great weekend.....pat
