What fuel pump for carbs?
Tim Cuddihy
PostPosted: Sat Aug 26, 2006 7:43 pm    Post subject: What fuel pump for carbs? Reply with quote
I am in the middle of rigging up some carbs on my car and was wondering what fuel pumps people use? Can I just swap over the current pump for a holley one that provides less pressure or do I have to remove the one inside the tank as well? I only intend to run 4.5 psi fuel pressure so if anyone has experience doing this I would be very grateful for some advice.
Thanks
PostPosted: Sat Aug 26, 2006 11:36 pm    Post subject: Reply with quote
I'd try removing the external pump altogether and see if the internal pump provides enougn flow and pressure.
OutOfTheBox
PostPosted: Sat Aug 26, 2006 11:54 pm    Post subject: Reply with quote
these guys have got the t-shirt when it comes to carbs
Quote:
My setup is 4 carbs from a GSXR 1100 bought on ebay for 80 € ( shiping cost includes, nearly $100 ), a Facet low pressure fuel pump
PostPosted: Sun Aug 27, 2006 2:37 am    Post subject: Reply with quote
I've used the Facet pump mentioned above on carb cars many times with great success. It will be a good alternative if the in tank pump cannot handle the job.
