Llamaguy
Posted: Mon Sep 25, 2006 7:08 am Post subject: Oil in Throttle body |
I noticed today that there was oil sediment in the front half of the TB and in the larger hose connected right next to the TB on the main air snorkle. I'm not sure, but I thought that that hose went to the brake booster and the like.
There's no oil on the back of the butterfly, so I know it's going toward the intake, and that's the only place the oil could be coming from. I also have a curious oil spot on top of the motor right under that connection so I assume that's where it is coming from.
So where's the oil coming from and how do I stop it.
PS, the motor doesn't smoke at all. _________________ 1987 924S Guards Red
Posted: Mon Sep 25, 2006 8:36 am Post subject: |
Oil breather? _________________ White 87 924S "Ghost"
Llamaguy
Posted: Mon Sep 25, 2006 10:13 am Post subject: |
I traced it back to something under the back of the intake manifold.
is the oil breather suppose to be putting oil into the intake though? _________________ 1987 924S Guards Red
Chrenan
Posted: Mon Sep 25, 2006 10:48 am Post subject: |
In the old 924 yes, it puts oil vapours back into the intake system to re-burn. Not sure about the 2.5 though. _________________ 1987 951 - M193 Version for Japan |
Posted: Mon Sep 25, 2006 11:09 am Post subject: |
The new ones too!
The oil filler tube also has an oil trap that has a hose that runs to the rubber intake hose that attaches to the TB. _________________ White 87 924S "Ghost"
pdubb
Joined: 27 Sep 2006 Posts: 3 Location: San Antonio,TX
Posted: Wed Sep 27, 2006 11:16 am Post subject: |
| I was reading somewhere that what you found could be blowback - which is a symptom of cars with worn rings/valve guides. The problem supposedly occurs in alot of high mileage cars - that might be the problem. If you have low compression that may be it. Just a thought! |
Llamaguy
Posted: Wed Sep 27, 2006 7:20 pm Post subject: |
no, the oil is only on the front of the butterfly and then only up to the point that the first vacuum line attachs so it has to come out of that hose. Must be the oil breather. Would it hurt anything if I disconnected and sealed both hoses? _________________ 1987 924S Guards Red
Chrenan
Posted: Thu Sep 28, 2006 12:50 am Post subject: |
I wouldn't seal the hose coming from the crankcase, you want the crankcase to be able to breath a bit, otherwise crankcase pressure will get too high and cause oil leaks. Supposedly a small vacuum in the crank case helps the rings stay seated, hence the routing through the intake. However, this does draw crap back into the engine. I've always wondered if the "helps the rings stay seated" story was just a ploy by environmentalists to have crankcase gases reburned as opposed to vented. In any case, at the very least run the hose from the crankcase into a catch can so there is still breathing allowed. _________________ 1987 951 - M193 Version for Japan |
