koolkarateguy
Joined: 16 Dec 2005 Posts: 108 Location: Nova Scotia ,Canada
Posted: Mon Sep 11, 2006 11:21 am Post subject: Homemade fuel injection line... |
Ok, so yesterday I'm replacing some coolant hoses, specifically the two stubby ones that come off the top of the water pump. Anyway, as I'm yanking on one of them to get it off , I hear a little "snap" under my right elbow. And there is an injector line snapped off right at the fitting.
What a bonehead. Anyway, what to do ? Of course I tried 3 parts stores knowing they wouldn't have the proper injection line but at least hoping for a fitting. I ended up at Canadian Tire. Saw some brake line. So the light came on. I bought about 4 feet of the smallest diameter they had. Took my busted fitting , sanded , cleaned it up and wrapped some copper wire around the nub that was left on the fitting to reinforce it and down the brakeline, fluxed it and using a propane torch soldered the broken fitting to it. Cut the line to length and flared it. Put the other fitting in the end and soldered it in place. Brought it out to the car and installed it . Works perfect !! Took some bending and such to get it to fit right but it works. At least I'll be able to use the car until my new injection line comes in. Anyway, just thought I'd share in case someone finds themself in the same predicament someday  _________________ 1979 N/A 924 |
endwrench
Posted: Mon Sep 11, 2006 12:26 pm Post subject: |
Probably better than the original! Maybe you should just make up 3 more
garyj19
Posted: Mon Sep 11, 2006 11:21 pm Post subject: |
ive been there. nice innovation though, wouldnt have thought of using brake line. _________________ early 77 924 na |
koolkarateguy
Posted: Tue Sep 12, 2006 11:46 am Post subject: |
I'm thinking of getting some brass stock the same thickness as the injector line fitting. I wouldn't think it would be all that difficult to make new fittings up using a drill press and a dremel , with a bit of filing . And then making a custom set of lines as endwrench suggested. The line I made looks like hell under the hood but if I measured and bent carefully it might come out looking ok , and it would be a lot stronger than my original homemade line. Worth a try anyway I guess. _________________ 1979 N/A 924 |
leadfoot
Posted: Tue Sep 12, 2006 7:31 pm Post subject: |
Fill them with sand before you bend them and this will help to stop it from kinking...
Leadfoot _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
