356speedster
Posted: Sat Sep 30, 2006 7:46 am Post subject: Peak power gone? |
Hi
My 1982 (ROW) 924na Manual is accelerating with a good pull up to about 5000 rpm, but then the pull just dissapears, and it feels like I have to push the engine up to the redline. in other words: there is no action above 5000 rpm. But it is smooth without any missfires or engine cut-out.
When reading about others that enjoy to take it to the redline, I figure there must be something wrong.
So I need to locate the problem, but what should I inspect/replace?
BTW: the engine does have serious ticking noise (sound like a diesel) so I guess it needs a valva adjustment, and there is an issue with high idle after engine is run hot. Not sure if these things are related tough. _________________ 1982 Porsche 924 na My 924 blog
1990 Porsche 928 S4 My 928 blog
1995 Fiat barchetta
2007 BMW 318d M-Sport
2010 Volvo V50 |
-nick
Posted: Sat Sep 30, 2006 8:12 am Post subject: |
Check to make sure your distributor is advancing as the rpm's go up.
It's a little tedious, but measure the distance between the 5 and 10 degree marks on your flywheel (or 0 and 10 or whatever) and make marks every 5 or 10 degrees on the flywheel with a marker - up to about 35 degrees. Then, with a timing light connected, raise the rpm's and watch that the marks move past.
Timing makes a big difference in peak power! _________________ 1980 931S
1991 964 C4 Cabriolet |
Posted: Sat Sep 30, 2006 10:01 am Post subject: |
Or get an advance timing light. . .way less tedious (and fun to play with).
Your car may be leaning out too. . .changed the fuel filter lately? _________________ Toofah King Bad
Posted: Sun Oct 01, 2006 5:59 am Post subject: |
The 924 engine does not make much hp, and the max is in the 4XXXrpm range.
Just what do you expect from the engine when you have already exceed the rpm where it makes the most power? |
356speedster
Posted: Sun Oct 01, 2006 8:00 am Post subject: |
| gohim wrote: | The 924 engine does not make much hp, and the max is in the 4XXXrpm range.
I know the 924 isn't a bullet, I usually drive a 350 HP tuned 928S4, but the last two weeks I've been using the 924 to work, wich is about the time it takes to get "normalized" after driving the 928
So ignore the debate about the 924 been powerful or not, the the car does have a noticable "pull" up to about 5000 rpm, but then it suddenly dissapears, wich I find strange. Especially after reading reviews wich state that the 924 engine must be driven hard to the redline to perform.
So I am assuming there is something wrong with it, and my best guess so far is: timing, fuel pump or vacume. But Since I dont know where to start looking I am asking here. _________________ 1982 Porsche 924 na My 924 blog
1995 Fiat barchetta
2010 Volvo V50 |
StienbargerR
Joined: 28 Oct 2005 Posts: 1362 Location: Richmond, IN
Posted: Sun Oct 01, 2006 10:51 am Post subject: |
Speedster, how many miles on your car? I think that the older cars get they probably just loose their peppy-ness. And have you tried just putting fuel injector cleaner in? That might help a little bit.
Ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
dpw928
Posted: Sun Oct 01, 2006 11:24 am Post subject: |
If your 924 is equipped with a catalytic convertor it could be partially plugged. Also, it could be running lean which would explain the dead top end and the hot running.
78 928 5 sp Silver
78 928 AT Euro Black |
