FASTdan
Posted: Mon Nov 27, 2006 5:10 am Post subject: fuel pump relay issue.... |
Hi Chaps,
I have been investigating the reasons behind the fuel pump not running over the last few days after purchasing a new relay (993 item) because the old one was missing when i bought the car.
It seems that the 2nd switch in the relay is not activating because pin 9 (which i believe should be permanently grounded) is switching to live on the turn of the ignition key. Because of this the 2nd switch is not closing and therefore i get no voltage at pin 4 - if i bridge 2 and 4 the pump works. I am getting power at pin 8 as expected when i turn the key.
Tracing pin 8 on the wiring diagram this appears to run to pin 20 on the DME unit. Therefore I have since tested all pins on the multiplug that should be grounded - eg pin 19, 17, 16....among others. All these appear to be grounded fine. This tells me that my DME unit is grounded ok, though i am no electrical engineer!? So, the question is, would this point to dry joints in the DME unit? OR am i on completely the wrong track?
I am right in thinking that the fuel pump should run when the key is in the 2nd position right? because someone did suggest to me that perhaps the ECU doesnt want the pump to run and therefore provides 12V to pin 8 on the relay....but i am thinking the pump should run at this point...
Any help/advice much appreciated, cheers! _________________ 1980 924LUX |
Posted: Mon Nov 27, 2006 10:53 am Post subject: |
The last section of this will help later in the process:
http://www.clarks-garage.com/shop-manual/eng-15.htm _________________ White 87 924S "Ghost"
FASTdan
Posted: Wed Nov 29, 2006 3:13 am Post subject: |
thanks Paul, that site is brilliant isnt it!! Cant believe I've missed it till now! _________________ 1980 924LUX |
