Valve Cover Nut
isuras2
PostPosted: Fri Nov 03, 2006 2:28 pm    Post subject: Valve Cover Nut Reply with quote
Is the valve cover nut any special size (threads)? I know it is 10mm (M 6). I dropped one which is now lost underneath the car in the engine bay (can't find it on the ground). When I started the car after losing it, there was some sounds from the engine, like maybe a nut. It may have fallen in the alternator, but I can't see it in there. Any (easy) way to get it out if it is in there?
Also, are the washers any special material or could I just throw a washer on there and be fine?
TIA
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Sat Nov 04, 2006 4:13 am    Post subject: Reply with quote
the washers have a slight flex in them to prevent them from backing off,
however if it possible that you dropped in inside the engine and it is in the oil pan?
3 928s,
isuras2
PostPosted: Sat Nov 04, 2006 9:37 am    Post subject: Reply with quote
No, the engine was closed as the valve cover was not off yet...this was the first nut.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Mon Nov 06, 2006 5:52 pm    Post subject: Reply with quote
Standard M6 coarse thread nut.
968rz
PostPosted: Tue Nov 07, 2006 12:27 pm    Post subject: Reply with quote
It is just a standard German metric nut.
I say German because; believe it or not in my 15 years as an auto tech I found that their is an Asian and German metric (at least on older cars), the difference is in the pitch of the treads; one will fit the other but will rock on the stud and could become loose
Rick
93 968 coupe Amazon Green 4spd Tip (my DD)
leadfoot
PostPosted: Tue Nov 07, 2006 1:46 pm    Post subject: Reply with quote
there are three pitches to every size. .75- fine, 1.0- standard, 1.25- corse...
if you use anything but what is intended you will cross thread whichever is the softer material... stud/nut
there is a sticky post in the genreal discussion section which has a link to a download for the porchse PET file... use it...
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
isuras2
PostPosted: Tue Nov 07, 2006 4:09 pm    Post subject: Reply with quote
Thanks, but I downloaded it when it first became a sticky...that is how I knew it was a M 6 nut. The PET says nothing about the thread pitch, but I'll go with the coarse thread as Mike924 says.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Tue Nov 07, 2006 5:58 pm    Post subject: Reply with quote
The ISO/DIN convention is that if the pitch isn't specified it means that the thread is standard (which is always the coarsest, I'm afraid, Leadfoot).
The standard pitch of M6 is 1.0 mm
Most metric sizes have a fine thread version and some of the larger diameter sizes have two, or even three, fine thread versions (in addition to the standard/coarse).
There is only one M6 fine thread version, with a pitch of 0.75 mm.
