Belt whine
Hoboceratops
PostPosted: Mon Nov 06, 2006 1:06 pm    Post subject: Belt whine Reply with quote
So I just got the head gasket, oil cooler seals, timing and balance shaft belts and various other minor things replaced in my 924S this week, so now it runs great; lope in the idle is gone, no smoke, much more smooth running overall.
BUT
and this is a big, round, full bodied but -
The engine is whining like crazy. Higher the rpm, higher the whine. Little reading up, possible the mechanic tightened the timing or balance shaft belt (the belt's been off for who knows how long, possibly years) too much? Or could it only be the timing belt?
Any tips would be pretty great, I'd like my belts to not explode on me.
1987 924S: Very much in love with it, even if it's all finnicky
968rz
PostPosted: Mon Nov 06, 2006 1:26 pm    Post subject: Reply with quote
It could be any of the belts. It's not that hard to loosen the acc belts (alt,ac.ps), but if you just had the work done I would take it back and ask the mech to check it out (if he cares about his work he should).
Rick
93 968 coupe Amazon Green 4spd Tip (my DD)
Hoboceratops
PostPosted: Mon Nov 06, 2006 1:29 pm    Post subject: Reply with quote
The acc. belts are fine, just checked them a little while ago, as my PS pump is loose on the mount and that belt is always finnicky. Not the problem, so it's gonna be the balance or timing then I think. >.<
Gonna pop the covers off and check the tension on the belts with the finger twist as a base and loosen it a touch to see if I can drop the whine, then take it to the shop tomorrow.
The most often cause of this whine is a balance shaft belt that's way too tight or the balance shaft idler pulley is installed too close to the balance shaft belt.
Hoboceratops
PostPosted: Mon Nov 06, 2006 1:36 pm    Post subject: Reply with quote
My money's on that, had to put a new roller in. If ya can, how should it be positioned and tensioned?
PS - The idler pulley, that was the roller with the eccentric hole, correct?
PostPosted: Mon Nov 06, 2006 1:39 pm    Post subject: Reply with quote
I found that if you tensioned the belt with turning the tensioner clockwise to tension that I could not get enough space between the idler roller and the belt, If you instead turn it counter clockwise to tension that you get alot more room of adjustment for the idler roller and that the whining noise almost completely disappears.
3 928s,
PostPosted: Mon Nov 06, 2006 1:52 pm    Post subject: Reply with quote
It's labeled "Balance Belt Idler Roller". It should just barely touch the belt.
Courtesy of Clarks Garage:
Hoboceratops
PostPosted: Mon Nov 06, 2006 1:58 pm    Post subject: Reply with quote
A'right, thanks a bunch you guys. Down to the garage I go.
timstar92404
PostPosted: Mon Nov 06, 2006 2:00 pm    Post subject: Reply with quote
the balance belt is also suppose to be pretty loose, I just tightened it just enough so it doesn't come off or slip. If you make it a little too tight the noise will be much higher.
I'm taking my car to a porsche shop to have it all tensioned by a professional with the 9201. Probably a good idea to take to a shop with the porsche tool to get the belts adjusted, it shouldn't cost much (maybe 1 hour labour).
when I had my belt adusted wrong it had a really loud belt whine I could hear inside the car with the hood and doors closed.
78 924 sold.
85.5 944
PostPosted: Mon Nov 06, 2006 2:02 pm    Post subject: Reply with quote
I recommend that you take it back to whomever installed it.....
Hoboceratops
PostPosted: Mon Nov 06, 2006 2:04 pm    Post subject: Reply with quote
Yeah, just gonna loosen the B.S. belt a touch and get it into the shop tomorrow.
PostPosted: Mon Nov 06, 2006 2:11 pm    Post subject: Reply with quote
The tension may be fine, check to see if the idler is causing the noise (since it's smooth and the belt has teeth, when the belt hits the idler, it howls).
Hoboceratops
PostPosted: Mon Nov 06, 2006 2:13 pm    Post subject: Reply with quote
Err.. sorry, that's what I meant
PostPosted: Mon Nov 06, 2006 2:15 pm    Post subject: Reply with quote
The purpose of that idler is to keep the belt on the balance shaft sprocket....
PostPosted: Tue Nov 07, 2006 2:11 am    Post subject: Reply with quote
iirc the manuals say that you should be able to fit a feeler guage between the idler roller and the BS belt. though I cannot recall the thickness of the feeler guage.
3 928s,
