johnrizo
Joined: 02 Jan 2007 Posts: 28 Location: Adelaide, Australia
Posted: Tue Jan 09, 2007 6:04 pm Post subject: lead additive |
hi
can anyone tell me whether or not (1981 porsche 924) i need to put lead additive into my fuel.
i mean is it supposed to run on leaded fuel or unleaded
thanks very much
regards
john |
Posted: Tue Jan 09, 2007 6:11 pm Post subject: |
Nearly all pre-'86 Australian cars were supposed to use leaded fuel. The 924 certainly was.
However, I run my '81 924 Turbo on unleaded and haven't had a problem. I've read that they're fine to on unleaded. But it wouldn't hurt to run the lead additive if you wanted to.
Here is a link to some info from the RACQ.
EDIT: Ah, I knew I'd seen this question somewhere before... _________________ '80 924 Turbo |
Posted: Tue Jan 09, 2007 6:54 pm Post subject: |
Not sure where I found this.
 _________________ Porsche 924 1984 (UK import) NA
Posted: Wed Jan 10, 2007 12:25 am Post subject: |
You might want to retard the ignition timing a few degrees if you run on 95 RON. There's some cryptic hint to that effect in the Owners Manual, but it's not at all specfic. I've set mine to 6° BTDC. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Wed Jan 10, 2007 6:55 am Post subject: |
we actualy have a fuel that is called "Carrera 100" and guess what..its high quality 100 octane fuel. i always use 98 oct because thats what i set my timing for. You always set your timing for a certain fuel, put another fuel instead and engine will not have the same performance. _________________ Supercharger and EFI kits
