rear main oil seal leak
sonicspeed17
PostPosted: Sat Dec 30, 2006 8:41 am    Post subject: rear main oil seal leak Reply with quote
ok I have the engine up on wood blocks and I am currently working on the front end of the engine (new water pump and all the timing parts) I just noticed a very small amount of oil on the ground near the back of the motor, and you can see that it has driped down from the rear main oil seal which i replaced before i installed the clutch now its only about a few drops a day but its still concerning, my question is, is this normal for a new seal like it needs to have the engine run and heat up to properly seal or did i just install it wrong and need to pull the clutch off and fix it.
thanks
-Justin
PostPosted: Sat Dec 30, 2006 1:39 pm    Post subject: Reply with quote
Your sure thats where its coming from..
sonicspeed17
PostPosted: Sat Dec 30, 2006 2:20 pm    Post subject: i think so Reply with quote
i wiped it clean and the next day it was there again (inbetween the bellhousing and the block) i cant think of anywhere else it could be from.
PostPosted: Sat Dec 30, 2006 3:36 pm    Post subject: Reply with quote
Could be anything that's above the point where you're seeing the oil. Check the rear cam cover gasket....
