Shadeslayer
Posted: Thu Jun 15, 2006 5:55 am Post subject: New Member with clutch pedal problems |
| Hi, I have an 87 924S that my dad picked up at an auction a while back. It seemed to be running fine until one time I pressed down the clutch and it wouldn't return. Have any of you had the same problem? |
Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Thu Jun 15, 2006 6:26 am Post subject: |
Sounds like the clutch cable broke.
Amended - that's the 924 response.
For the 924S... it is most likely faulty clutch master/slave cylinders _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
Posted: Thu Jun 15, 2006 7:13 am Post subject: |
Most probably either the clutch master or clutch slave cylinder has died.
Have you noticed the brake fluid going down? That would be because the clutch is fed from the same reservoir as the master brake cylinder. If the clutch master cylinder is leaking, very often, the fluid ends up on the carpet under the driver's feet, and there won't be a visible leak under the car.
They are fairly inexpensive, and you should be able to buy the pair for $150 or less. Change both now, when one dies, the other isn't far behind, and bleeding the clutch is not any fun at all, so you don't want to do it twice. While you are in there anyway, you should go ahead and bleed the brake system as well. Infact, I would bleed the brake system first to get rid of the old contaminated fluid before I even installed the new clutch cylinders. That way, you will not be filling your new clutch parts with the crude that is going to kill them. |
Shadeslayer
Posted: Thu Jun 15, 2006 7:36 am Post subject: |
Thanks for the quick responses, I'm going to check it out now. _________________ 1987 Silver 924S |
Posted: Thu Jun 15, 2006 8:46 am Post subject: |
| gohim wrote: | Most probably either the clutch master or clutch slave cylinder has died.
In addition to excellent advice above, since your hose from the brake master cylinder reservoir to the clutch MC and the hose from the cltuch MC to the clutch slave is probably 20 years old, consider replacing them both. _________________ White 87 924S "Ghost"
Shadeslayer
Posted: Thu Jun 15, 2006 11:11 am Post subject: |
I have noticed a leak under the car, but not on the carpet under the driver's feet. How doable is replacing those parts to the clutch and relevant hoses? Considering where I obtained the 924S, I was thinking of doing a complete teardown to see what else needs replacing, besides just the clutch. But what work would be worth having done at a dealership/shop? _________________ 1987 Silver 924S |
Posted: Thu Jun 15, 2006 11:17 am Post subject: |
That depends on your skill level, the availability of the necessary manuals and tools.
A clutch job on a 924S is not a trivial task, some have given up in the middle of the job, others have taken weeks. Some of us can do it on a single Saturday with a cooperative car. A single bolt that has corroded or a PO tightened too tight can add considerable time and aggravation. _________________ White 87 924S "Ghost"
Posted: Tue Aug 01, 2006 10:40 am Post subject: |
Dear god, I was just looking at the slave cylinder removal in Haynes (my master is just beginning to seep). . .
Is it accurate? Remove the exhaust & wastegate? Axles? Starter? Use an engine hoist?
AIEEEEEEEEEEE!
Posted: Tue Aug 01, 2006 12:44 pm Post subject: |
The slave cylinder is held by two bolts and is near the starter. _________________ White 87 924S "Ghost"
Posted: Wed Aug 02, 2006 1:54 am Post subject: |
| Paul wrote: | | The slave cylinder is held by two bolts and is near the starter. |
Sheesh, so Haynes is incorrect about the massive teardown to get to it, then?
Whew! _________________ Toofah King Bad
ronined
Posted: Tue Dec 05, 2006 5:40 am Post subject: |
Shadeslayer,
Like gohim, Once I got the clutch master cylinder working right the slave crapped out a week or so later. If you replace one, replace the other.
Ed _________________ '87 924S |
Posted: Sun Dec 10, 2006 10:25 am Post subject: |
I have the slave cyl rebuild and reinstall process down to <1 hour from doing it so many times.
I bench bleed, then reconnect the hydraulic line before bolting the slave back in - this simplifies the bleeding, which I don't even do - I just pump the pedal to finish the job.
Combine the slave replacement with a starter solenoid cleaning since the starter's out anyway. -And dribble some Liquid Wrench or whatever onto that center button inside the solenoid and push down on it to provide the internal switch parts with some rust prevention. I actually dribble on the fluid, then smack the button down repeatedly to dislodge any oxidation and clean those hidden switch contacts.
Once the slave goes bad and starts to leak, some of that leakage goes into the starter solenoid, gunking it up with a dirt/fluid concoction and promoting rust since the fluid is hygroscopic.
I would say if you have to replace the master, do the slave as well if you like.. -But since the slave goes bad way more often than the master, you don't always have to replace/rebuild the master when the slave goes bad. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Shadeslayer
Posted: Thu Dec 28, 2006 11:14 am Post subject: Now that the slave cylinder is removed... |
First of all, thanks to the members who replied to the problem I'm having. Due to school/work/vacation, I've been unable to get to the problem until now. I just got done removing the clutch slave cylinder and checking to see if it's smooth inside. For feedback I'm going to post a few pics of the inside of the cylinder. I'd appreciate the feedback very much.
Then I'll get to work removing the clutch master cylinder!  _________________ 1987 Silver 924S |
Posted: Thu Dec 28, 2006 12:16 pm Post subject: |
Pics are always good to look at, so go ahead if you have the time, but the condition of the bore is more of a judgement call based on feel more than sight. I'd be willing to guess you found the rubber bellows piece torn, then some dirt/gunk inside beyond it. Anyway, take the slave cylinder to a freind that messes with cars and seems to be experienced and good at it to get their opinion on the condition of the bore if you're not comfortable with judging it yourself. I have 2 slaves that I swap back and forth and neither one is perfect - there are a few small signs of rust, but no deep pitting - just tiny 1-2mm diameter spots that I'd estimate are similar in roughness to worn down 800 grit sandpaper.
Advance AutoParts has the slave rebuild seal kit at about $17. Autozone has it at about $5-$10 more than that.
Unless you like an adventure or you know it's been a long time since the master has been serviced, I would just finish up the slave and take it from there. Deal with the master seperately if you find there's still a problem. _________________ "..it's made in Germany. You know the Germans always make good stuff."
