drewnashty
Posted: Mon Jan 01, 2007 2:35 pm Post subject: Headlamp Relay |
Anyone know where to find the original "Headlight/flasher and low beam relay" on a 1981 931? I have read about the upgraded headlamp relay for the upgraded lights and I can only find a wire harness kit to rewire my system. With the upgraded relay can I install the relay in the original slot or not and will it have any ill effects on the stock headlights. The relay panel is currently jumpered for the headlamp and I have no low beams but have high beams. Have not been able to find the original relay on any online retail stores or autozone/checkers. _________________ 81 931 |
AGD931
Joined: 17 Mar 2003 Posts: 289 Location: Athens, Greece
Posted: Tue Jan 02, 2007 4:18 am Post subject: |
I replaced mine last month, genuine part, the part number is
111 943 383 C
Hope this helps
Arthur _________________ 1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia |
Posted: Tue Jan 02, 2007 5:23 am Post subject: |
Arthur - that's the headlight motor relay. It's not for the lights themselves. We don't have a relay for the headlights - as drewnashty found his panel is just jumpered instead. Though I'm not sure if mine is even jumpered..I'd have to look. -But I know there is no relay - it would be in the bottom row, far left.
Drewnashty - Not sure what you're doing, but the wiring diagrams show that relay present up to years '79 or '80. Have you tried asking for a 1979 or earlier year "headlight dimmer relay" or "dimmer/headlight flasher relay"? _________________ "..it's made in Germany. You know the Germans always make good stuff."
drewnashty
Posted: Tue Jan 02, 2007 6:27 am Post subject: |
| Smoothie wrote: | | Drewnashty - Not sure what you're doing, but the wiring diagrams show that relay present up to years '79 or '80. |
Just trying to get my damn low beams to work lol. In my Haynes it doesn't mention the years for that relay, so I had just assumed they all had the relay there. Would prefer not to mickey mouse it.
| Smoothie wrote: | | Have you tried asking for a 1979 or earlier year "headlight dimmer relay" or "dimmer/headlight flasher relay"? |
I'll check it out _________________ 81 931 |
Posted: Tue Jan 02, 2007 7:17 am Post subject: |
You don't need it. I just had a look at mine - there's no relay in that spot, just a jumper between pins at the upper-left that correspond to the relay pins 56-56b. See the wiring diagram on Haynes pg. 293, it shows the relay missing at top-center above current tracks 16-18 (just above fuses 1 and 3 (btw check those fuses)).
If the fuses are ok, my next suspect would be the "dimmer/headlight flasher switch" on your steering column and shown at the bottom-left of page 293. Could also be a burnt-oxidized pin D17 on the back of the fuse-relay board. _________________ "..it's made in Germany. You know the Germans always make good stuff."
