ATE Super Blue Brake Fluid
ronined
PostPosted: Thu Dec 14, 2006 5:16 am    Post subject: ATE Super Blue Brake Fluid Reply with quote
Are there any compatibility issues with ATE Super Blue Brake Fluid and ordinary DOT3/4 fluid? Do lines have to be drained and flushed with alcohol?
Thanks,
Ed
'87 924S
moliver
PostPosted: Thu Dec 14, 2006 7:55 am    Post subject: Reply with quote
No issues. Its good stuff.
87-924s
genikz88
PostPosted: Fri Dec 15, 2006 3:35 am    Post subject: Reply with quote
+1
I use it in my GTi and my 88 924S with no issues. I just added it to the master cylinder and flushed it through with a power bleeder.
Chris
'88 924S
JSilverman
PostPosted: Mon Dec 18, 2006 1:09 am    Post subject: Reply with quote
There actually is a compatability issue with the GTI. Its been more audi related (A4s and TTs)but the superblue damages seals in the clutch system. Some symptoms are a squeaky clutch pedal. I use the ATE typ200 in my 924s with no problems. I just dont like the fact that the whole system gets dyes with the superblue.
genikz88
PostPosted: Fri Jan 12, 2007 1:57 am    Post subject: Reply with quote
Good point, I forgot about that. I have no issues at this point, and the blue stuff will be flushed with typ200 in March.
Chris
'88 924S
ronined
PostPosted: Wed Jan 17, 2007 1:23 am    Post subject: Reply with quote
ATE typ200? What are the characteristics of this fluid?
Isn't the SuperBlue supposed to have a higher boiling point than average brake fluid?
Ed
'87 924S
PostPosted: Wed Jan 17, 2007 2:08 am    Post subject: Reply with quote
oops. . .see below. . .
JSilverman
PostPosted: Thu Jan 18, 2007 5:08 am    Post subject: Reply with quote
Ed
Typ 200 is the DOT approved non blue version of the superblue. It has the same properties as the blue stuff except for the dye.
genikz88
PostPosted: Fri Jan 19, 2007 11:46 am    Post subject: Reply with quote
Rasta Monsta wrote:
I flushed with this stuff (also synthetic), no problems yet, and very good track performance
Most quality 'racing' brake fluid will have published or advertised boiling points. That's really the key. Any temps listed on that Prestone bottle?
Chris
'88 924S
JSilverman
PostPosted: Sat Jan 20, 2007 3:32 am    Post subject: Reply with quote
I had to buy some of that for my GTI the other day when I wore through a front brake line. It had a boling point slightly higher than standard DOT 4 fluids. Its kind of like the Valvoline Synpower fluid, or Castrol LMA, a little better than DOT4 for about the same price.
PostPosted: Sat Jan 20, 2007 3:50 am    Post subject: Reply with quote
Oops, this is the one I used, and temps are on the bottle. . .
20v924
PostPosted: Mon Jan 29, 2007 9:59 am    Post subject: Reply with quote
As much as I hate Motul, they have a wonderful racing fluid they call 300v. Its boiling point exceeds any I have found thus far and is completely compatable with all makes of cars. Its kinda pricy though.
A person is smart. People are stupid
