Posted: Fri Dec 29, 2006 3:49 am Post subject: OP Sender Readings. . .HELP?!? |
Anyone know the correct resistance for the OP sender when no pressure is present (ie, what resistance makes gauge read "0")?
Also, is it a mistake to use thread sealer on the sender (for grounding purposes)?
TIA
Posted: Thu Jan 04, 2007 12:55 am Post subject: |
I know someone knows the answer to this. . . _________________ Toofah King Bad
Joined: 29 Jul 2001 Posts: 9134 Location: Royal Oak, MI, USA
Posted: Thu Jan 04, 2007 5:19 am Post subject: |
infinite (open circuit) will cause it to read 0. _________________ Vaughan Scott
Posted: Thu Jan 04, 2007 5:22 am Post subject: |
So that means, disconnected should read zero, right? So, if the gauge is pegged when disconnected at the sender, I have a short in the sender wire?
Thanks, V _________________ Toofah King Bad
Posted: Thu Jan 04, 2007 7:09 am Post subject: |
Exactly! _________________ Vaughan Scott
Posted: Thu Jan 04, 2007 7:29 am Post subject: |
So, seems like I should just rewire it with a fresh length of wire doesn't it? _________________ Toofah King Bad
931Tony
Posted: Mon Jan 22, 2007 6:36 pm Post subject: |
| You're right on not using any sort of thread sealer on the OP sender. Almost all single wire sender/sensors ground through the block, so you might check that too. G'luck! |
