johnwalklett
Joined: 17 Nov 2003 Posts: 31 Location: staffs england
Posted: Thu Jan 25, 2007 5:44 pm Post subject: Fresh air blower resistor location. |
Could anyone tell me where the resistors for the fresh air fan speed controle are on a right hand drive 1982 924. Before I dive in stripping things down.
thanks
John |
Posted: Thu Jan 25, 2007 5:59 pm Post subject: |
Earlier cars had them hidden under the front panel (the one with the P badge), but I think yours will be inside the heater intake (under the windscreen, behind the bulkead) along with the fan.
Is there a problem with the blower? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Fri Jan 26, 2007 6:32 am Post subject: |
"under the front panel" - Are you sure about that?
I'm guessing you have the interior blower and radiator fan resistor locations confused. Early rad fan resistors were up front somewhere like that. Later rad fan resistors were placed in the dash..
Early fresh air blower resistors (one 10ohm resistor) have to be in the dash somewhere - the manual shows them grounding at (1) which is near the fuse-relay panel. That 10ohm resistor provides a resisted path to ground that bypasses the blower speed switch, providing low-speed operation of the blower when the ignition is switched on. There's also some resistance built-into the blower speed switch itself (slider control) for mid-speed and a non-resisted position for high-speed. (Talking the early hvac system here with 3 full-width slider controls.) The switchover from early to later hvac system occured during model year '82 production, so you could have either one depending on the manufacture date and VIN.
If you have the later design, you'll have a rotary blower speed switch, 2 half-width sliders and one full-width slider. -In which case you should find the resistor/s in the middle area of the dash, somewhere between the rotary switch and blower motor. Sorry - I don't know where they are exactly, but should be easy to find by following the wires from the rotary switch. _________________ "..it's made in Germany. You know the Germans always make good stuff."
johnwalklett
Posted: Fri Jan 26, 2007 6:42 am Post subject: |
I have the later design, with a rotary blower speed switch, 2 half-width sliders and one full-width slider.
Speeds 1 has not been working since I had the car 3 years ago, but now speed 2 is not working either and I am left only with speed 3.
I have the wiring diagram in my workshop manual, but was unsure where to start looking for the resistors. I'll have to have a look for them this week end..... wish me luck.
John |
Posted: Fri Jan 26, 2007 8:11 am Post subject: |
Resistors are almost bullet proof.
I'd suspect the switch first. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri Jan 26, 2007 8:39 am Post subject: |
Yep. . .buy a can of "Electrical Parts Cleaner" and blast away. . .bet that takes care of it. _________________ Toofah King Bad
Posted: Fri Jan 26, 2007 9:37 am Post subject: |
| Ozzie wrote: | Resistors are almost bullet proof.
I'd suspect the switch first. |
Umm, not on mine. On mine the low value resistor (medium speed) was fried when I got the car. However, I'm not sure if the apparent fire fried the resistor, or if the resistor started the fire. Which ever way it was though there was melted wiring around the fan motor, including the small value resistor.
Being unfamiliar with how it's supposed to work, and due to the fact someone had previously started to disable the A/C, when it came time to get power to the blower motor, I had 2 speeds available from the blower control, and 3 speeds available on the fan. I chose to have it "off", "low" and "high," since this looked like it was the most similar to how things worked with the A/C when I looked at the wiring diagrams. Perhaps I should modify this to "low", "medium" and "high" if this is what is expected in other '24's.
Prior to reassembly, I did not realize there were only two speeds available from the selector, so I repaired the wiring with a couple 25 watt resistors (in parallel) to duplicate the original 3 speed arrangement. It turns out the "medium" speed resistor (low value) that I replaced isn't used at all. In order to keep this on topic, indeed, these resistors are found adjacent to the blower motor, cooled by the incoming airflow, on the top side of the blower unit. _________________ 78 924 NA
5-lug |
Posted: Fri Jan 26, 2007 5:40 pm Post subject: |
| Smoothie wrote: | "under the front panel" - Are you sure about that?
I'm guessing you have the interior blower and radiator fan resistor locations confused. |
You're right, of course, Smoothie.
I f**ked up again!
I'm pretty sure the later type has the resistor mounted inside the plastic 'fencer's mask'. It looks like a green tube. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
