924 engine life?
jesse wall
PostPosted: Sat Mar 24, 2007 6:24 am    Post subject: 924 engine life? Reply with quote
What is life of 924 engine? What are the most miles you know of without rebuild? What is life with rebuilds like rod bearings and rings ? Thanks just wondering as I keep hearing about engines being taken down and what great shape they are in, , curious Jesse
jesse wall 'new driver' , 87 924s
PostPosted: Sat Mar 24, 2007 6:56 am    Post subject: Reply with quote
I have read on these forums about 100k engines being disassembled and still showing cross-hatching marks in the bores, so it would seem the bottom end does very well. . .however I don't think you can get away with putting off headwork for much beyond that.
-nick
PostPosted: Sat Mar 24, 2007 7:14 am    Post subject: Reply with quote
^ sounds about right. The bottom end is for diesel abuse after all.
Headgaskets and valve guides / stem seals seem to need replacing north of 100k miles. Although, a lot of these cars have been abused with oil changes / overheating / etc. Leaky gaskets aren't uncommon on the oil pan, which is somewhat of a pain.
1980 931S
1991 964 C4 Cabriolet
Andrew NZ
PostPosted: Sat Mar 24, 2007 11:40 am    Post subject: Reply with quote
Mine had done about 300,000km's before I finally seized it by over heating it in a rally. When it cooled down I topped up the oil and water and finished the rally (another 500km's) before I stripped it down and found the original honing marks in the block. I have most of the service records from new and it doesn't look like it had ever been rebuilt before!
These things are bullet proof!
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
Andrew NZ
PostPosted: Sat Mar 24, 2007 11:44 am    Post subject: Reply with quote
I forgot to mention that they were standard size bearings and rings that came out........and standard size that went back in!!!
Andrew
1977 RX924 race car
jesse wall
PostPosted: Sun Mar 25, 2007 8:59 am    Post subject: Reply with quote
wow!! What a neat thing to hear , thanks Jesse
StienbargerR
PostPosted: Mon Mar 26, 2007 2:40 am    Post subject: Reply with quote
yeah. my car has 180,000, and i runs ok, except i burns oil pretty bad.
ryan
1978 924 NA
-250lb lowering springs, Euro Pistons
Raceboy
PostPosted: Mon Mar 26, 2007 3:07 am    Post subject: Reply with quote
My wifes '83 924 has 300 000+ kms on it and no rebuilds plus I turbocharged it few days ago.
Check Performance upgrades forum, there's topic about it.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Mon Mar 26, 2007 8:21 am    Post subject: Reply with quote
Yeah, I've found the 2-liters to be pretty robust down low, hard to kill except through neglect... though I've seen my share of those!
5150
PostPosted: Mon Mar 26, 2007 8:08 pm    Post subject: Reply with quote
Well, the odometer on my 1978 hasn't worked since the late 1990's, but looking through the history folder and service receipts I know the car cleared 200k miles by the time I bought her. I had a piston ring break a couple of years in so I'd say it was around the 250k mark that we changed the engine to a reconditioned one.
Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead.
geddes66
PostPosted: Wed Mar 28, 2007 2:19 pm    Post subject: Reply with quote
The crosshatching still shows on my sons '77, built Sep '76. The oil pressure is too high cold (7.5-8.5 bar) and too low hot (2.5) but replacing the filter with a short one and wrapping it in foil helped, (headers heating oil through filter via radiant heat?) an oil cooler is on the to do list.
I am running 5W-50 synthetic oil. I think the relief valve is stuck closed but haven't tried to remove it yet.
The Porsche is now my son's, my car is cooler, slower but cooler.
