the easy way, or the hard way....
running_cold924
PostPosted: Wed Aug 16, 2006 11:39 am    Post subject: the easy way, or the hard way.... Reply with quote
ok, i want to adjust or check out my linkage in my 79 924 for the tranny linkage. i have the 016Z tranny though with the backwards reverse setup.
instead of pulling the exhaust, heat shields, and torque tube, couldn't i just remove the rear seat and cut upen the floor ih the middle to get to it and i coul also just make a door to close it back up if i ever needed back in....
let me know if you guys have ever tried this... or even if it will work!
1979 Porsche 924 n/a with dual Mikuni's(sold)
1987 Porsche 944S, chipped (traded)
1986 Porsche 951, Vitesse MAF, 83lb injectors, 3 inch exhaust, Garrett turbo (sold)
1892 Porsche 931, sport seats, mostly original but not running
leadfoot
PostPosted: Wed Aug 16, 2006 11:51 am    Post subject: Reply with quote
Yes check out Vaughn's site... 924RACR... he has done exactly that...
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Wed Aug 16, 2006 11:52 am    Post subject: Reply with quote
me too I followed him. the hole route made
it cake. I got a pic for ya. of what I did/
I even made 2 holes.
PostPosted: Thu Aug 17, 2006 12:51 am    Post subject: Reply with quote
you can do that to be able to access the bolt for being able to undo it, but you will still have to do everything else to be able to remove the shift rods, the hole is just for making it easier to be able to access the top two tranny bolts and the single shift rod bolt.
3 928s,
running_cold924
PostPosted: Sat Aug 19, 2006 11:58 am    Post subject: shifts Reply with quote
okay, but what do I need to repair when my shifter is sooo loose? like when its in neutral, i can move it back and forth about 2 inches, just slop right, i know its not trying to be put in gear, but its still moving the shift rod to the tranny. every thing is tight at the shifter itself, so it has to be back at the tranny right? thats why i was wondering about the hole to see if it was something I could tighten up or need a major amount of work to fix.....
any suggestions?
PostPosted: Sun Aug 20, 2006 1:04 am    Post subject: Reply with quote
there are 2 bushings on the shifter linkage at the tranny end and one ball cup bushing,
to replace them you must remove the shift rods, and to do that you have to drop the tranny, if you do that I would recommend that you cut the ball that the ball cup goes onto off, and then weld a bolt in place and replace the ball cup with a hiem joint held on by a nut on top of the bolt.
for the shifter rod bushings I would recommend that you have 2 pieces that look like the factory rubbr pieces made out of aluminum, this will solve the problem for as long as you own the car.
3 928s,
der uber
PostPosted: Fri Mar 30, 2007 11:26 pm    Post subject: Tips on avoiding brake lines Reply with quote
Any tips on drawing out whee to cut?
Sounds like avoiding the brake lines are the top concern.
Advice? I will be performing this mod soon.
1980 931 converted to n/a
My first project
