kirmet
Joined: 31 Mar 2007 Posts: 7 Location: Eatonville, Washington
Posted: Sat Mar 31, 2007 10:26 am Post subject: Poor Running at high rpm |
I have a 1980 924 Turbo, it has been siting for more than ten years in a garage. I recently took it out and fired it up. at first it ran pretty good. I have ran a couple of tanks of gas through it and now it is hesitating, learching and dieing.
I have replace the fuel filter (on my third rust in the tank).
I know it needs a cold start valve. hoping not related.
Any help would be great. _________________ 1980 924 Turbo
1959 Austin Healey
1960 MG |
D Hook
Posted: Sat Mar 31, 2007 12:02 pm Post subject: |
There's a few different things to check but before you do anything else, have you changed the timing belt?
If that breaks, the rust in the tank will be the least of your worries.  _________________ '80 924 n/a SOLD |
kirmet
Posted: Sun Apr 01, 2007 1:31 am Post subject: Poor running 924 |
the timing belt and water pump were changed shortly before it went to storage, it is however on my list of things to do again because it has been sitting so long. as well as the cold start valve. (hard to start cold)
It needs a fuel pump (noisey but appears to have good preasure)
At times it runs fantastic and you drive it with perm-a-grin then it just starts stumbling like its not getting fuel. I have checked the accessable vacume lines and have trimmed off any loose fitting one.
I let it sit overnight and it runs fine again for while. _________________ 1980 924 Turbo
1959 Austin Healey
1960 MG |
Tigger937
Posted: Sun Apr 01, 2007 1:41 am Post subject: Re: Poor Running at high rpm |
| kirmet wrote: | | I have replace the fuel filter (on my third rust in the tank). |
I would remove the in-tank fuel pump and check/remove any foreign matter in the tank that has accumulated there over the past 25 years. _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Posted: Sun Apr 01, 2007 2:44 am Post subject: |
When you replace a fuel filter on a US 931, make sure you install it with the arrow pointing towards the back of the car (towards the fuel dizzy). _________________ White 87 924S "Ghost"
