Gaskets, thing of the past, seemingly
PostPosted: Mon Apr 02, 2007 5:54 pm    Post subject: Gaskets, thing of the past, seemingly Reply with quote
I'm going to replace my camshaft over the Easter break, so I'll need to remove the dizzy housing and therefore it'll need a new gasket for when I put it back on. Also, for an unconnected reason ( ), I need to replace the thermostat housing, which will, obviously, need a new gasket.
I went to half a dozen places to get the gaskets: no-one does them! Not just for a 924, no-one does gaskets - period! "We can sell you a complete head set, sir". Thanks a bunch!
OK, so no gaskets. How about some gasket paper so I can make up my own? "Don't sell that either, sir" Arrgh!
So what are you supposed to do? Eventually, I got a guy at a place that services trucks to take pity on me and let me have some of their stock of gasket paper.
PostPosted: Mon Apr 02, 2007 6:33 pm    Post subject: Reply with quote
I buy gasket paper at the local generic parts store.
Usually has plenty.
PostPosted: Mon Apr 02, 2007 7:01 pm    Post subject: Reply with quote
That's right, rub it in!
There just aren't enough tinkerers in the UK anymore for shop to stock stuff like that. We must be a dying breed!
Jaf
PostPosted: Mon Apr 02, 2007 8:41 pm    Post subject: Reply with quote
Yeah I couldn't find any gasket paper either. Used a heavy duty brown envelope in the end!
1978 924na
Tigger937
PostPosted: Mon Apr 02, 2007 9:25 pm    Post subject: Reply with quote
.........and what's even tougher is trying to find asbestos based gasket material for exhaust items. ...........or are folks just knuckling under and buying the outrageously priced OEM stuff? What are folks using here?
Mike924, I was able to find the regular gasket material at the local generic parts store for the thermostat and dizzy housing and make my own.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
jimcarver
PostPosted: Mon Apr 02, 2007 10:24 pm    Post subject: Reply with quote
Have you tried here? It looks like they have the distributor gasket.
http://www.porscheshop.co.uk/acatalog/porsche_924_gaskets_seals.html
PostPosted: Mon Apr 02, 2007 11:32 pm    Post subject: Reply with quote
Thanks for that, Jim. Good find.
It's £3 for a dizzy housing gasket, which converts to over £7 when you add in VAT and postage (and VAT on the postage!)
I managed to find a throttle gasket from another car in my 'box-o-bits', which fitted the thermostat housing (with a bit of fettling).
Unless the dizzy housing gasket's ridiculously too complicated, I'll have a go at making one from the gasket paper I've now managed to get. If not, I'll have to swallow my pride and dig into my pocket...
PostPosted: Tue Apr 03, 2007 6:39 am    Post subject: Reply with quote
I made both recently and its a breeze with the paper.
IIRC the thermostat also has an 'O' ring.
PostPosted: Tue Apr 03, 2007 5:05 pm    Post subject: Reply with quote
Thanks, Ozzie.
It's the thermostat housing gasket where it bolts to the head I need - I didn't think there was a gasket at the stub-pipe end; just the O-ring as you say.
Great pic of the dizzy housing! - this is exactly what I needed to see. Thanks. Like you say, it looks a pretty simple simple thing to knock up (apart from the eight(!) bolt holes!).
I'm much happier now with the plan of making a dizzy housing gasket and won't be forking out the £7+ (Aus $20!) for a 'proper' one.
Thanks, again.
PostPosted: Tue Apr 03, 2007 6:24 pm    Post subject: Reply with quote
I use the ball part of the ball pein hammer for the holes after doing the large hole first.
Put the bolts in the holes to hold the gasket paper still and go around the outside with the hammer.
The paper cuts away leaving the shape you see in the pic.
( the thermo above was from the daughters car)
I also use a non hardening sealant both sides on assembly.
PostPosted: Tue Apr 03, 2007 7:53 pm    Post subject: Reply with quote
Sorry, Ozzie, I'm being a bit thick, here.
Can you explain the bit with the hammer a bit more? You don't mean clout the part to cut through the paper, do you?
Hylomar Blue!
PostPosted: Tue Apr 03, 2007 8:39 pm    Post subject: Reply with quote
In the top pic is a small ball hammer.
I tap the paper along the edge of the part you want the gasket for.
The sharp edge of the part cuts the paper.
like so
PostPosted: Tue Apr 03, 2007 8:46 pm    Post subject: Reply with quote
Right! I get it (Sorry for being so thick!)
Very ingenious! Thanks, Ozzie.
PostPosted: Tue Apr 03, 2007 9:33 pm    Post subject: Reply with quote
welcome
PostPosted: Wed Apr 04, 2007 12:07 pm    Post subject: Reply with quote
Ozzie, there must be a way to combine your technique with some other technique that doesn't involve hammer-related whacking.
