924LUX
Posted: Sat May 19, 2007 5:00 am Post subject: rev counter |
Right then i had just finished fitting my shinny new crank shaft and bearings to me engine (that was still in place), when i turned her over for the first time in about..... forever, it started lovely with no loud nocking to be heard at all when i noticed after doing the little dance of joy that the rev counter was not holding a stedy reading, and jumping up to 456 thou evan thought the engine was running smoth as. any body had this prob b4 and know how to fix . i submitted a poll a few months bck about oil pressure and crank shaft condition, and if there dirrectly related and low an behold they are my readings are 6-7 cold and 3-4 bar warm so thanks those who answered you saved me from getting a pump to i did make a few video recordings of it being started during the final stages but i dont know how to post them sorry. _________________ 1985 Porsche 924LUX 2 ltr N/A
every cloud has a silver lining except the mushroom shaped ones in which case thats a bad thing !!! |
Posted: Sat May 19, 2007 5:51 am Post subject: |
Check the FAQ. . .jumpy tach needle answer lies within. _________________ Toofah King Bad
924LUX
Posted: Sat May 19, 2007 7:56 am Post subject: rev counter |
this is all i can find there :
"My speedometer/odometer is bouncing/not working. Why?
The speedo is mechanically driven off of the front left wheel"
Im on about the rev counter any sugestions? _________________ 1985 Porsche 924LUX 2 ltr N/A
Posted: Sat May 19, 2007 9:55 am Post subject: |
The tach is electrically driven of the coil- bad wiring is usually the cause. _________________ Porsche 924 1984 (UK import) NA
924LUX
Posted: Fri May 25, 2007 4:44 am Post subject: coil |
have checked the connections on the coil and have filed and copper greased the earth points by the fuse box and still its bouncing what kinder test could i do on a multi meter apart from a continuity test to see if its the wires themselfs that are at fault and is there any other places that the cables go to endup at the display. as far as i can gues its from coil to fuse box then display, is this any where near correct ?  _________________ 1985 Porsche 924LUX 2 ltr N/A
Jaf
Posted: Fri May 25, 2007 6:27 am Post subject: |
Sorry I'm no help about the rev counter. Just wondering where you got your crank from. I'm about to take a look at mine to see whether I can get it reground or not. Also how'd you go about getting the main crank to pulley bolt off? I tried years ago but bent my mates snap-on breaker bar! He was not impressed. _________________ 1978 924na |
Posted: Fri May 25, 2007 8:58 am Post subject: |
| Jaf wrote: | | Sorry I'm no help about the rev counter. Just wondering where you got your crank from. I'm about to take a look at mine to see whether I can get it reground or not. Also how'd you go about getting the main crank to pulley bolt off? I tried years ago but bent my mates snap-on breaker bar! He was not impressed. |
I use a breaker bar (3/4 drive), rotate the motor with the bar CW until it is resting against the body.
On turbo's, do this with the timing belt on.
Remove ign wire from coil and hit the starter. The starter motor will rotate the engine and 'crack' the bolt.
Do not let the motor start - hence the remove ign wire- or crank too long.
On turbo's this is fatal or will damage the locating pin on the oil pulley. _________________ Porsche 924 1984 (UK import) NA
Jaf
Posted: Fri May 25, 2007 6:15 pm Post subject: |
| Ozzie wrote: |
On turbo's this is fatal or will damage the locating pin on the oil pulley. |
Ah. Quite sure we didn't try that trick. Had a tool in the starter motor hole to lock the fly wheel and then a large bit of pipe over the breaker bar. Tried the old heating up/ hitting malarky. Will try your trick. Probably in a few weeks as I'm a bit tied up at the moment. Thanks! _________________ 1978 924na |
924LUX
Posted: Sat May 26, 2007 2:48 am Post subject: bolt |
to get the crank pully off i had the engine out once b4 and losend it off then since the car had not been on the rd since it was easy enough to get off lol i got the crank from a guy in newport sold it to me for £130 plus all bearings to mach the reground it had dont know if he has any more though. going back to rev counter does any one know of a decent wiring diagram of this circuit thanks.  _________________ 1985 Porsche 924LUX 2 ltr N/A
Posted: Sun May 27, 2007 4:01 pm Post subject: |
The late model 924 had the same tacho as the 944 without the economy guage. _________________ Porsche 924 1984 (UK import) NA
Posted: Mon May 28, 2007 5:42 am Post subject: |
A 944 tach gets its signal from the DME. _________________ White 87 924S "Ghost"
Posted: Mon May 28, 2007 7:59 am Post subject: |
My tach has two multiplugs, one going to the speedo and the other going of to the coil etc. _________________ Porsche 924 1984 (UK import) NA
924LUX
Posted: Mon May 28, 2007 10:06 am Post subject: |
DME??? _________________ 1985 Porsche 924LUX 2 ltr N/A
Posted: Mon May 28, 2007 11:00 am Post subject: |
I don't know if a 2 liter 924 ever had one....
Bosch Digital Motronic Engine-management (DME)
http://www.atlllc.com/atlantis.php?page=Motronic%20Editor _________________ White 87 924S "Ghost"
Posted: Mon May 28, 2007 2:27 pm Post subject: |
No- just to power and ign system. _________________ Porsche 924 1984 (UK import) NA
