Stampedetrail
Posted: Tue May 22, 2007 7:10 pm Post subject: New preignition condition |
Hello again. Last thursday I was cruising around like normal, and I've recently had the wheels balanced so I thought I'd take the highway and see if that annoying wobble is gone away now. Up over 70 MPH, no real problems, the wobble is still there but not nearly as bad as before. I take it home and think, boy that idle sure is high, almost 2K, maybe crank that down a little. So I do that, go out to get some food and something is wrong. Preignition, that clack-clack in low gear under load, very persistant and appearing quite suddenly.
Following the code if it aint broke don't fix it, I assumed I had caused this condition by messin' with the idle, so I adjusted that back to where it was. No change. I adjusted the mixture a bit richer, no change. I adjusted the timing a bit retarded, no change. I filled 'er full of premium and drover 'er around the neighborhood for half an hour, no change. WTF?! What did I do?
I pulled the plugs, NGK slightly hotter than stock, they looked perfect--light greyish-tan with no spots, pits, or anything, except a little carbon built up around the rim (the threaded part). Replaced them with Bosh standard plugs, no change, and a lot less vroom.
I've ordered a fuel filter, but I have very little faith that this will solve my problem. It's a very persistant preignition condition that has just appeared suddenly and is not going away! Help!!
BTW, this is the car _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
Posted: Tue May 22, 2007 7:45 pm Post subject: |
My guess.
Your centrifugal advance in the dissy is stuffed which has your timing well advanced to start with and none when you want it. _________________ Porsche 924 1984 (UK import) NA
Stampedetrail
Posted: Wed May 23, 2007 5:37 pm Post subject: |
Good idea, that would mean though that in a crisis situation I could retard the ignition a bunch and eliminate the preignition, but so far not. On your comment I just tonight replaced the cap & rotor & examined the dist., did not see any obvious signs of any failure. No change in condition because of that tho. I wonder if it could just be carbon build up in the head. Sticky valve possibly? Just can't quite guess, but it definitely does not sound mechanical. Spose I need to do a compression test & pop the valve cover (sigh)
Though I wonder if its possibly a valve-timing issue? That would be some troubleshooting. Who's going to come and help me rebuild this thing  _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
Posted: Wed May 23, 2007 7:28 pm Post subject: |
I f your springs in the cent advance are ok you can turn the rotor approx 20deg and it will spring back. _________________ Porsche 924 1984 (UK import) NA
Posted: Wed May 23, 2007 10:22 pm Post subject: |
Could also be a vacuum leak in the intake tract or a duff/leaking vac advance on the dizzy. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Stampedetrail
Posted: Thu May 24, 2007 6:39 pm Post subject: |
| Ozzie wrote: | | I f your springs in the cent advance are ok you can turn the rotor approx 20deg and it will spring back. |
Ah! It does spring back. So am I to understand that there's a centrifugal as well as vacume advance in the distributor? I've been running it with no advance or retard lines, plugged at the manifold of course, and its been just fine until now. Haynes on transistorized ignition, in theory "no engine which relies on rotating mass as the means of producing power can turn faster than the ignition system can produce spark. Ignition remains "dead on" at all times and under all conditions..."
What does this mean?
| Quote: | | Could also be a vacuum leak in the intake tract or a duff/leaking vac advance on the dizzy. |
The dizzy is not an issue but I'll thoroughly check the vacume on the manifold, though I immediately rebuilt the throttle body seal when this started happening. Wonder about that crankcase air breather?
I dont know, maybe I'm over-analyzing it. Preignition exists when the charge ignites before the spark goes off, so something is causing that to happen. Hmmm. _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
Posted: Thu May 24, 2007 6:53 pm Post subject: |
Reconnect the vacuum advance and see if it makes any difference. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Fri May 25, 2007 2:22 am Post subject: |
| Stampedetrail wrote: | | Preignition exists when the charge ignites before the spark goes off, so something is causing that to happen. Hmmm. |
If this were the case, than your ignition timing wouldn't matter at all. Since clearly it does, this is an over-simplification of what preignition really is.
I'm no expert, and there have been a number of in-depth discussions here about it, so it would probably be a good idea to do a search. There's also a distinction between "knocking" and "preignition", and the term "pinging" is often used to describe both conditions.
One of the above conditions is caused by spontaneous combustion due to very high cylinder pressures, which happen because the charge is ignited sooner than it should, allowing the gasses in the cylinder to expand due to combustion as the volume of the chamber is decreasing more than designed. The remedy to this condition is to retard the ignition timing. _________________ 78 924 NA
5-lug |
Posted: Fri May 25, 2007 8:48 am Post subject: |
In my case I was running a bit lean, riching the mixture made all the diff. _________________ Porsche 924 1984 (UK import) NA
Stampedetrail
Posted: Sat May 26, 2007 12:54 pm Post subject: |
| !tom wrote: | | Stampedetrail wrote: | | Preignition exists when the charge ignites before the spark goes off, so something is causing that to happen. Hmmm. |
One of the above conditions is caused by spontaneous combustion due to very high cylinder pressures, which happen because the charge is ignited sooner than it should, allowing the gasses in the cylinder to expand due to combustion as the volume of the chamber is decreasing more than designed. The remedy to this condition is to retard the ignition timing. |
Thank you for your help here. I did try retarding it, but it will not start well in that condition and we were still experiencing preignition. If I don't find the answer soon, the engine is coming out. No sense replacing the head with a rebuilt one with so many miles on the bottom end. _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
Posted: Sat May 26, 2007 11:27 pm Post subject: |
Check your rotor, cap, and the electrical connection at the distributor. _________________ White 87 924S "Ghost"
Stampedetrail
Posted: Sun May 27, 2007 7:06 pm Post subject: |
Too late I'm afraid. I already replaced the rotor & cap & rebuilt the connection to the distributor. Then I took that all apart & started removing the engine. _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
