dgKnecht
Posted: Sun Aug 12, 2007 11:20 am Post subject: rat-mobile resurection |
hi guys, long time no see......
i let my 924 sit for almost two years
rats got in it,
i think i got all the feces vacuumed out, looks like they left the seats
alone, i'll know more when i remove them and look at the undersides.
there is a hole in the passenger side carpet right in the corner between the
torque-tube and the firewall, bunch of styrofoam crumbs there, guess that is
where the nest was. Also found some piles of leaves in the engine compartment,
and the air filter is gone
they ate the foam around the shifter then ate through the boot to get inside.
wish me luck guys, i need to inspect every inch of dash wiring and engine harness,
also will have to totally flush fuel system and oil.
Then maybe new carpeting and seat covers?
--if i don't get discouraged and just part it out. _________________ 78 924
--all of us have been through some bad times.....i once had a job where i had to drive a Chevette  |
-nick
Posted: Sun Aug 12, 2007 11:26 am Post subject: |
^ why I never park alongside Boston Common You should have see the size of these visitors last night, sheesh.
Seriously, sounds pretty ugly. The foam around the torque tube under the shifter goes a long way to keep out noise, heat, and exhaust. I don't envy you. _________________ 1980 931S
1991 964 C4 Cabriolet |
Stampedetrail
Joined: 29 May 2005 Posts: 274 Location: Fairbanks, Alaska
Posted: Sun Aug 12, 2007 12:13 pm Post subject: |
There's supposed to be foam around the torque tube below the shifter? I have to check this out! _________________ 1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can. |
Posted: Sun Aug 12, 2007 2:02 pm Post subject: Re: rat-mobile resurection |
| dgKnecht wrote: | maybe new carpeting and seat covers?
Yes, + an extreme cleaning with protective gear on I'd say - respirator, etc. and bleach (does that kill viruses?). Those little nasties can carry some nasty disease still long after the plague. One is hanta virus -
http://www.cdc.gov/ncidod/diseases/hanta/hps/noframes/rodents.htm
-Not to scare you tooo bad - just enough so you'll know to take precautions. _________________ "..it's made in Germany. You know the Germans always make good stuff."
924guy
Posted: Mon Aug 13, 2007 12:52 am Post subject: |
smoothie hit the nail on the head, i recently went through some safety training that covered rodent /pest control, some of it was rather scary. a 50/50 solution of bleach /water in spray bottle should neutralize the "threat." don't forget the gloves and mask...
sounds like a great project, looking forward to seeing the progress... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Mon Aug 13, 2007 1:02 am Post subject: |
Great info, I'll take those deer mice more seriously going forward! We usually catch a few each fall in our basement. _________________ White 87 924S "Ghost"
jazz guy
Posted: Mon Aug 13, 2007 2:42 am Post subject: |
In Colorado, there are usually several cases of hantavirus each year. Most do not have a happy ending. As mentioned previously, it is spread from mouse droppings and secretions. IIRC, deer mice are the major carriers, though not all are infected.
Definitely use a bleach solution or antibacterial/virul cleaner to gently spray the droppings before moving them. Avoid cleanup methods that allow particles to get airborne, as this is when they become a real hazard.
No need for undo alarm, but it is something to keep in mind. |
rat
Joined: 02 Nov 2004 Posts: 92 Location: Colchester, Essex, UK
Posted: Mon Aug 13, 2007 5:28 am Post subject: |
I like how you tell him this stuff AFTER he's already hoovered the thing  |
Posted: Mon Aug 13, 2007 5:55 am Post subject: |
Wow, what a timely coincidence - an actual rat?!
nyuk nyuk nyuk
Yeah a topic starting with "what should I do?" rather than "here's what I already did.." would have been better in this case.
There've been a few instances of mice and rat encounters mentioned here over the years. Plus one that could be used as a natural rodent control - that would be about the guy that found a snake in his engine compartment. As far as mice/rats are concerned, Joe once found his vent ducts full of pellets that were either put there by hoarding mice (most likely) or they were D-Con poison pettets put there by a previous owner to get rid of rodents (or a villain trying to get rid of Joe ). In another case, mice or their junk was found in a clutch or transmission bellhousing area. I think they've been found in with air filters as well.
It was quite a few years ago that I first heard of hanta virus on the news. Since then, I always go in with a spray bottle of bleach+water and give the area a good spraying first, and wear a respirator. -Then wash the clothes with bleach added. _________________ "..it's made in Germany. You know the Germans always make good stuff."
dgKnecht
Posted: Tue Aug 14, 2007 5:27 am Post subject: |
| rat wrote: | I like how you tell him this stuff AFTER he's already hoovered the thing  |
yeah, i was thinking,"too late"
can't really spray bleach on black carpet eh? maybe just use
a steam cleaner on it? _________________ 78 924
Posted: Tue Aug 14, 2007 5:46 am Post subject: |
It depends on what the carpet is made of. If it's a dyed material, then no - (or yes, but plan on re-dying it). If it's made of something like polypropylene, then you can dump bleach on it all day and it won't loose the color (my Jeep Cherokee has red carpet that's apparently made of some "poly" material - I've sprayed bleach all over it with no affect on the color). -But there's been discussion several times here about re-dying the carpet and that it works, so apparently our OEM carpet would loose its' color with bleach.
-But test an inconspicuous area first, then either bleach and not worry, or bleach and re-dye, or try the steam (you're talking actual hot steam right? (some cold water carpet cleaners call themselves and what they do "steam cleaners" and "steam cleaning" even though no real steam or hot water vapor is involved)). I'm pretty sure that heat kills viruses.. That's how the human body deals with them, right? _________________ "..it's made in Germany. You know the Germans always make good stuff."
