Looking for opinions on shocks
Goto page 1, 2, 3  Next
B
PostPosted: Sun Sep 02, 2007 5:12 am    Post subject: Looking for opinions on shocks Reply with quote
It appears to be time to change the shocks (rear for sure - fronts might not need it just yet) I was looking at some of the shock options and as much as I would love some bilstein's or koni's my budget won't allow it right now. I also found Boge, Monroe and KYB. I wondered if anyone has had any experience with these 3 and if they thought any one was better than another. My application will be street for now, but I still want to enjoy the handling strength of the 924. Monroe and KYB are very affordable but I did not know how good they were for our cars.
Any input would be greatly appreciated.
thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Sun Sep 02, 2007 7:17 am    Post subject: Reply with quote
If you don't have the money to buy good shocks, save what you have till you have enough.
Boge/Sachs are OEM, unless you have Factory Optiona/ Konis, or Bilsteins.
Boge Turbo Gas would be my fourth choice, after Bilstein Sport, Bilstein Heavy Duty, then Koni Gas.
After that would be KYB Gas-Adjust, Not KYBs lowest quality non-adjustable products.
Last, and not worth installing would be Gabriel and Monroe.
Which car to buy?
PostPosted: Sun Sep 02, 2007 8:35 am    Post subject: Reply with quote
So "Bilstein Sport, Bilstein Heavy Duty, then Koni Gas." is 1-3, cool.
Last edited by Which car to buy? on Mon Sep 03, 2007 3:19 am; edited 1 time in total
John Brown
PostPosted: Sun Sep 02, 2007 1:33 pm    Post subject: Reply with quote
Somewhere I've seen a quote complimenting Porsche for designing a very good handling car without the necessity to use extremely high spring rates. One benefit of that is the shocks don't HAVE to be super stiff. Recall that shocks are closely related to the vehicle weight and spring rate.
I've not said it this year. If you do a search I'm sure you'll find me repeating myself often. For STREET driving it is almost impossible to safely drive so hard that any decent shock is not adequate. The high end Koni or Bilstein are nice but NOT required. If you do have that kind of cash laying around I do like the Bilsteins. Monroe is, uh, Monroe. I even gave up on the Escalade and put Bilsteins back on in place of the Monroes.
That leaves Boge or KYB. Either one is fine. I even did DE for a long time on the stock suspension using KYB and it worked fine.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
PostPosted: Sun Sep 02, 2007 7:56 pm    Post subject: Reply with quote
I should have said something about Koni Reds.
I would say Bilstein Sport #1. I have Red Konis right now, and they are too soft even for street driving.
Bilstein Heavy Duty is the standard Bilstein, I did not rate them #1 as they are not recommended for a lowered car by the manufacturer.
I guess Koni Sports (Yellow) would be #3
Koni Red would #4 for me. They are too soft for most purposes are far as I am concerned because you have to turn them all the way up so you don't bottom the car in street driving. Might be okay for an earlier car (77), which is much lighter.
B
PostPosted: Sun Sep 02, 2007 9:16 pm    Post subject: Reply with quote
this is probably a stupid question, but do you/should you use the same brand front and rear? or are there some interchangeability with brands?
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Sun Sep 02, 2007 9:53 pm    Post subject: Reply with quote
Absolutely use the same.
I'll add my vote to Boge or KYB for the street; KYBs will be cheaper than the former, though. FWIW, I used the Gas-A-Just as gohim mentioned - didn't realize they had cheaper ones.
While you're in there, get new front upper strut mounts, and consider having an alignment done, and also replacing front a-arm bushings. Makes a huge difference to how the car drives - it'll feel all new after all that! Did it to my '82 931, it's lovely on the street, doesn't feel old anymore.
B
PostPosted: Sun Sep 02, 2007 10:14 pm    Post subject: Reply with quote
thanks
I was going to start in the rear because I have to do the brakes too - so I thought since the shocks were getting weak it was a good time to do that
when I get to the front - hopefully by spring - I will do like you said and change bushings and check the front brakes. Does it matter where you start - front or rear?
So the kyb gas adjust will be fine for the street? will they be stiff enough?
Are there any bushings that I should check in the rear while I'm there?
Sorry so many little questions - I'm just trying to be as thorough as I can so I can try to do it right once.
thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
924guy
PostPosted: Sun Sep 02, 2007 10:59 pm    Post subject: Reply with quote
i have koni sports all around, set on medium (2 clicks) and find them to be very well suited to my 931 with stock springs, for both average and more "spirited" driving.
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
Vince Ponz
PostPosted: Sun Sep 02, 2007 11:12 pm    Post subject: Reply with quote
Bilstein gas shocks are perfect for street and mild track days. Have them on two cars.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
John Brown
PostPosted: Sun Sep 02, 2007 11:21 pm    Post subject: Reply with quote
gohim wrote:
... I did not rate them #1 as they are not recommended for a lowered car by the manufacturer.
... They are too soft for most purposes are far as I am concerned because you have to turn them all the way up so you don't bottom the car in street driving. Might be okay for an earlier car (77), which is much lighter.
Is the car under discussion lowered? If so how much? You can't lower it too damn much without getting into serious clearance and steering geometry issues.
Bottom the car in street driving? What's that got to do with the shocks? Bottoming indicates, first of all, a spring rate not consistent with the setup. Shocks are selected and adjusted to optimize handling. Not ride height.
Not intended as a negative comment about anyone or anything. But it is, I think, an interesting data point to note that the two people who actually race the cars (VS and myself) both think the Boge or KYB are just fine for street driving of any kind. Even 'spirited'. And we both use or used them on our street cars.
John
80 931 - #931 44Cup
B
PostPosted: Sun Sep 02, 2007 11:55 pm    Post subject: Reply with quote
I have original/unaltered springs and what appears to be a level stance front to rear - I am not trying to skimp on parts just trying to find a reasonable replacement that will maintain the integrity of the 924's handling abilities. kyb and boge seemed reasonable if they will do the job well - right?
thanks
B
1979 924 n/a
BAE turbo
5-speed snailshell
PostPosted: Tue Sep 04, 2007 1:51 pm    Post subject: Reply with quote
I have been trying to get some shocks (all 4) to replace on my car.
In Oz they are either rare or bloody expensive.
I'd be happy with KYB's as I only use the car for around town.
I've tried ordering thru the US but the freight was dearer than the parts.
Would anyone be willing to purchase and post to me?
part nos for KYB are kg4529 and 363014
I've found some on E-bay but they havent replied about freight.
Neil924
PostPosted: Wed Sep 05, 2007 5:01 am    Post subject: Reply with quote
I could help you out. Did you have an Ebay link you were bidding on? Or are you looking at a website? Someone down south might be able to do it cheaper. No rush.
PostPosted: Wed Sep 05, 2007 7:32 am    Post subject: Reply with quote
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=011&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=320150195823&rd=1
and
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=011&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=320150203179&rd=1
which ship free in the USA.
I have a price of $136 freight from them so I might take them up. about $388 au. total.
Page 1 of 3
