On a hoist, is there anything to be careful of?
Neil924
PostPosted: Mon Sep 10, 2007 5:23 am    Post subject: On a hoist, is there anything to be careful of? Reply with quote
Where should the 4 pads rest on the underside of the car?
Thanks.
I know about the jacking points but I think the hoist pads are larger and will hold all of the weight of the car.
endwrench
PostPosted: Mon Sep 10, 2007 5:47 am    Post subject: Reply with quote
It is usually best to lift at the body pinch points along the edge if possible. Most hoist have arms too long to do this so I usually place the front ones under those two unibody "frame rails" near the tunnel and the rear ones under the lowest point of the torsion tube. Hard to explain without a picture. Just don't lift off the belly pan or any moving suspension parts.
Todd
PostPosted: Mon Sep 10, 2007 6:30 am    Post subject: Reply with quote
+1
PORSCHEV
PostPosted: Mon Sep 10, 2007 6:47 am    Post subject: Reply with quote
I like to use 2 points on the front. The pivot point for the rear mounting part on the control arms and on the rear I like the rear suspension mount points. They are meant to carry the weight of the car already.
1978-#53 "D" track racer.
PostPosted: Mon Sep 10, 2007 8:24 am    Post subject: Reply with quote
Whatever you do, do not place the hoist lift pads under the shock mounting cups/points on the trailing arms. What will happen is that you will crack and break the shock mounting cups off the trailing arms, requiring replacement of the trailing arms.
I have had the idiots at two different tire shops cause this disaster when having my tires replaced at different times.
Needless to say, I always stand right there now, and make sure that the guy lifting the car is placing the hoist pads in places that I direct they be placed.
Neil924
PostPosted: Mon Sep 10, 2007 11:26 am    Post subject: Reply with quote
That's one way to get free trailing arms though it may not be the easiest way of replacing them!
