GRATIAN Guest
Posted: Wed May 15, 2002 3:45 am Post subject: |
| has anyone find an explicit presentation of Haynes Manual on the net? (for 924 s or 944) |
Skimdude Guest
Posted: Wed May 15, 2002 5:19 pm Post subject: |
I am very interested in an online Haynes manual as well. There has never been made a 924S manual by haynes, so the best solution would be a 944 manual.
carnut280 Guest
Posted: Fri May 17, 2002 12:27 pm Post subject: |
| I gotsa 944 Haynes manual...it's not the greatest, but it helps with the little repairs. just DO NOT trust it with your timing. they recommend adjusting the tension with drill bits. but, to not mess it up, you need a very expensive tool from Porsche... |
davidyendell Guest
Posted: Mon May 20, 2002 12:25 am Post subject: |
There is a 924 Haynes manual numbered 397 here in the UK. Apparently they are a bit like hens teeth. It does not cover the 2.5 litre 924S introduced in Sept 1985.
The ISBN number is ISBN 1 85010 438 7. Good luck with your search.
[ This Message was edited by: davidyendell on 2002-05-20 00:27 ] |
