Fuel Level Sending Unit
skytrooper
PostPosted: Thu Oct 25, 2007 4:24 am    Post subject: Fuel Level Sending Unit Reply with quote
The one in my 1987 924S is not functioning (most likey from sitting in varnish gas for 10 years)...anyway, is the fuel sending unit from a 944 interchangeable ?
PostPosted: Thu Oct 25, 2007 4:47 am    Post subject: Reply with quote
Early ones, yes I think so...
joecitizennn
PostPosted: Sat Oct 27, 2007 9:34 am    Post subject: Reply with quote
You might try removing it, and gently shaking it to see if the float is moving. If the float is free, but you dont have a signal you can take the unit apart by unscrewing the very bottom (plastic cap on bottom of aluminum tube). The thing is held together by a rod that is threaded on the very bottom. The float rides up and down the rod and has contacts that touch very thin wires. (Hair thin wires!) If these are broken (likely) you will need another unit.
skytrooper
PostPosted: Sat Oct 27, 2007 12:00 pm    Post subject: Reply with quote
I will check it when I have it out. I got another one on ebay "on the way".
As always...
Thanks Joe !
