Valve Adjusting Screw
gla924sem
PostPosted: Sun Oct 28, 2007 5:48 am    Post subject: Valve Adjusting Screw Reply with quote
Never have liked the 1 notch adjusting screw that came on my 82NA.
Seemed that you could never get a good adjustm,ent hot or cold
Been thinking about replacing with the 4 notch
Anyone done this and what is your opinion???????
Anyone have a used set to sell???? Will need eight
PostPosted: Sun Oct 28, 2007 6:22 am    Post subject: Reply with quote
I'm curious, how much are they through PCNA?
PostPosted: Sun Oct 28, 2007 2:11 pm    Post subject: Reply with quote
If you are even close to the correct lash with a 1 notch wedge, a 4 notch wedge is NOT what you need.
John Brown
PostPosted: Sun Oct 28, 2007 10:31 pm    Post subject: Reply with quote
How far off are you?
$7.00/each from PCNA
John
80 931 - #931 44Cup
99 Escalade - tows track cars
PostPosted: Mon Oct 29, 2007 12:07 am    Post subject: Reply with quote
The number of notches refers to markings on the adjuster wedge. The more notches, the thicker the wedge, the more 'wear' it takes out.
It is NOT the number of 'clicks' you get per rotation; that is always one!
Most tappets need somewhere in the range of 2 -3 notch adjusters by this time.
PostPosted: Mon Oct 29, 2007 12:14 am    Post subject: Reply with quote
See here <click>
PostPosted: Mon Oct 29, 2007 2:24 am    Post subject: Reply with quote
Does that mean a new cam & followers (assuming the base circle portion of the grind is factory correct) should take "one-notchers?"
PostPosted: Mon Oct 29, 2007 5:53 pm    Post subject: Reply with quote
Can't say for sure, Rasta.
There is also a 'zero-notcher' size.
